Post new topic Reply to topic  [ 88 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Wed Jun 06, 2012 5:46 am
That is great looking bike ! Congratulations. One question, I noticed that you wrapped something around the saddle rails. What did you use to wrap it with ? I assume this is to protect the finish of the rails, right ? Thanks
PostPosted: Wed Jun 06, 2012 7:31 pm
Saddle comes like that. It's a carbon wrap.
PostPosted: Sat Jun 09, 2012 9:38 pm
I told you that you would love the Veloflex. Way better than the high end tires from Conti and/or Michelin.
Plus the latex tubes you used makes the ride amazing.
http://www.hackracer.com/
PostPosted: Sun Jul 15, 2012 11:32 pm
Omni racer titanium seatpost clamp fail:
Time to find something new to replace this. Now I am all nervous about lightweight clamps...and I am not even that heavy!
PostPosted: Sun Jul 15, 2012 11:44 pm
I have had great luck with the Woodman Deathgrip SL Ti clamp (and I am quite heavy). Weighed 11g on my scale.
My Bikes
My Photoblog
PostPosted: Sun Jul 15, 2012 11:48 pm
I think you should get an extralite ultraClamp to match your stem.
PostPosted: Mon Jul 16, 2012 1:24 am
Both good options.
I like the idea of matching the stem. I also like the idea of something in silver to match headset and hubs. Extralite, New Ultimate, Woodman, and Tune all don't make a silver one. Don't like the looks of the KCNC one either.
PostPosted: Mon Jul 16, 2012 3:16 am
Yikes. I can report the one I recommended to you (same as on my Helix) is still going strong.
PostPosted: Mon Jul 16, 2012 9:22 am
The bolt snapped on my Extralite clamp, I think it is Ti ???
I also managed to round out the Extralight headset bolt on my bike when I was carrying out some routine maintenance, it was like it was made of chocolate !!! I really like Extralight stuff but after two bad experiences, one involving need to be rescused 40miles from home I won't be using any of their bolts in future.
I use Thomposon seat clamps on all my bikes, not the lightest but good enough for Firefly bikes is good enough for me.
Enigma Echo
PostPosted: Mon Jul 16, 2012 2:02 pm
I mentioned to Cheers in a IM while discussing the Extralite clamp, it seems that a lot of these lightweight clamps don't use a rotating barrel nut. As soon as the 2 faces of the clamp (threaded area, and surface for the bolt head to rest) are not parallel, the head of the bolt gets side loaded. The Hope seatpost clamps are notorious for this, and the bold heads snap right off. The Parts of Passion clamp actually looks pretty good for this reason, despite being as mere 7g.
Is that how the bolt snapped on your Extralite clamp?
Thomson is definitely a consideration.
PostPosted: Mon Jul 16, 2012 4:47 pm
It is as good a reason as to how it broke for me. It was making a bit of noise in the ten or so miles before the break, a little slippage, then when tightening, bang, Game Over !!!
Anyway, I don't want to muddy up this thread of this lovely Lynskey, my only expereience is that for some things it is better to go a little heavier and get something a bit more beefy !!!
Cheers,
Si :-)
Enigma Echo
PostPosted: Tue Jul 17, 2012 7:40 pm
nspace wrote:
Both good options.
We've had some luck removing anodizing without removing material. Plus our $5 buffing wheel is still going strong. So let me know if you need some stripping and polishing done.
PostPosted: Sun Aug 05, 2012 9:03 pm
Still absolutely loving this bike. I have made some changes since my first post.
- Scrapped the Kurve saddle. Wasn't for me (not to mention it was pretty porky)
- Replaced with Fizik Arione CX with carbon rails
(The white stripe ties in nicely to the white stripe between the faceplate on the 3T bars since I didn't go with a 3T stem)
- Put on a Hope seatpost clamp I had kicking around in the mean time until I decide on which new clamp to get
- Added Race Ware Direct 200/500 Garmin right hand mount
- Added Dog Fang chain catcher for security
Total weight is at 7.0kg or 15.48 lbs.
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
Users browsing this forum: Google Adsense [Bot] and 18 guests
There are no new unread posts for this topic. Lynskey R330 ML and L Frame weights?
iamalex
13
946
Tue Jun 26, 2012 9:36 pm
nspace View the latest post
There are no new unread posts for this topic. FS: Complete Cyclocross Build Kit Sora 9 Speed
j_gantzer
Fri Mar 08, 2013 4:50 pm
j_gantzer View the latest post
There are no new unread posts for this topic. Attachment(s) Starting on the long spiral down
1spd
11
2136
Wed Dec 19, 2012 9:04 pm
1spd View the latest post
There are no new unread posts for this topic. New Project: Lynskey CX Disc
Ramjm_2000
10
1635
Wed Aug 08, 2012 1:17 pm
Ramjm_2000 View the latest post
There are no new unread posts for this topic. Lynskey Cooper-Size Md
cmdr199212
Mon Apr 22, 2013 2:12 pm
cmdr199212 View the latest post
It is currently Tue May 21, 2013 8:42 am
