Post new topic Reply to topic  [ 7 posts ]
PostPosted: Mon Jan 30, 2012 11:07 pm
So I installed my new lovely new FC-M985 cranks on my Cannondale Flash F3 Alloy, and noticed the clearance between the driveside crankarm and the chainstay is quite tight (about 3mm), but not critical.
I just wanted to confirm the tight 3mm clearance is acceptable for this crank? And I wonder what is the best case scenario for this crank since the q-factor is 3mm less on each side than the M980- ie most frames would have this same issue?
The bottom bracket is 73mm so I have one 2.5mm spacer on the driveside cup. I gather I can't cheat and add another spacer since the non-drive side wouldn't have enough spindle?
Other than that, amazing crank, light and very well finished!
Many thanks
PostPosted: Tue Jan 31, 2012 4:46 am
3mm is fine. cranks dont flex much in that direction when in the rearmost position.
PostPosted: Tue Jan 31, 2012 5:03 am
Many thanks for the reply thisisatest, pretty much what I was thinking/hoping.
I knew the M985 crank had a small q-factor, but I was surprised to see how small the clearance was! I can see these cranks wouldn't be compatible with a lot of frames eh?
PostPosted: Tue Jan 31, 2012 9:38 pm
just bought the same cranks, and my clearance is even less. 2mm max. don't know if it functionally matters, but just looking at it is a bit disconcerting. do you notice that your non-drive side has more clearance? the difference is noticeable on mine.
PostPosted: Tue Jan 31, 2012 11:25 pm
Yes, you're right the clearance on the non-drive side is about 4-5mm. Sounds like I'm not the only one then! I'm guessing this is the price you pay for a low q-factor.
PostPosted: Sun Jun 24, 2012 4:20 am
As a follow-up to this I have noticed the drive-side crank arm on my M985 crank has a slight rub mark, as well as on the chainstay. Only very minor, but it is definitely making contact at some point.
So it seems the crank/frame is flexing and under certain conditions perhaps with additional mud there is a rub.
Not good, but do I need to worry about it? I'll post a pic.
PostPosted: Wed Jun 27, 2012 1:01 pm
I tried fitting one (44/30T) to a Trek 9.9 (2007/8?), and the large chainring fouls the chainstay before the crank seats against the BB bearing!
It might fit if I remove the chainsuck plate, but I'm not gonna risk that!
I've now fitted it to my SC Blur XC - it's very close on that - around 2-3mm max, but does fit.
Anyone else had the same issue with other frames?
Users browsing this forum: Bing [Bot], gifted child and 10 guests
There are no new unread posts for this topic. Firecrest / Enve Smart chainstay clearance
12x23
15
1177
Sun Sep 16, 2012 12:05 am
12x23 View the latest post
There are no new unread posts for this topic. m985 crank bigger gap for crank arm bolt to spindle?
in MTB
tzeonn
Tue May 14, 2013 7:49 pm
tzeonn View the latest post
There are no new unread posts for this topic. 1x10 for Shimano M985
in MTB
WolfTooth
Sun May 05, 2013 3:53 pm
WolfTooth View the latest post
There are no new unread posts for this topic. XTR M985 brake lever reversable?
in MTB
hjb1000
7
580
Wed Aug 22, 2012 3:34 pm
yourdaguy View the latest post
There are no new unread posts for this topic. XTR Shadow plus RD-M985 SGS vs GS cage length
in MTB
Tsielio
Fri Oct 12, 2012 9:56 pm
stephen@fibre-lyte View the latest post
It is currently Thu Jun 20, 2013 6:33 am
