Post new topic Reply to topic  [ 18 posts ]
Go to page 1, 2  Next
PostPosted: Wed Aug 04, 2010 7:26 pm
Has anybody tried to remove the big red anodized plug from the inboard side of a Formula R1 Brake caliper, i.e. this bit ?
I would really like to anodize the part a different colour and need to know which tool is best (due to funky shape) and whether it was a complete nightmare or a piece of cake
Thanks in advance.
Si.
Enigma Echo
PostPosted: Wed Aug 04, 2010 7:55 pm
If it is like most brakes, you just need the 5 sided tool and it should screw right out. But you will probably need an overhaul kit since the brake fluid will run out and while you are anodizing it, the seals might dry up and probably get contaminated too. This is going to be a heck of a lot of work for that little bit. Why not just get a black Sharpie marker and color it or paint it with black paint?
For certain parts stiffer is more important than lighter.
PostPosted: Thu Aug 05, 2010 2:47 am
All R1 color combinations come from a guy in Italy thet sells the sets on ebay.it I can PM you his email, so maybe you could purchase this part anodized black if that's what you need, or he could do a different color for you. Who knows.
Chris.
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Thu Aug 05, 2010 9:06 am
I have done on my brakes. I made the little tool at work and it came right out. The reason for doing this was to anodize the caliber gold and the cap black so it fit my Scott Scale LTD. you have to be aware of that it is a nightmare to bleed them afterwards as they have been completely empty of fluid.
Enjoy your work.
Morten Nørgaard
braking is the first sign of fear!!!!!
PostPosted: Thu Aug 05, 2010 9:45 am
Cheers for the replies guys, I try to answer each individually !!!
I probably will colour it in with a black marker, the other red bolts on the caliper and master cylinder / brake lever are easy to remove and will be anodized in green, I really wanted to get this part green as well but it might be a bit too much of a hassle to do, I don;t want to wreck my new brakes !!!
Chris.
I did order these brakes from the guy in Italy (clood69 on Italian eBay) because I wanted the white R1 with carbon levers, I just can't get green anodized ones to replace the red bits.
Enjoy your work.
Morten Nørgaard
Was it very tight / hard to remove ? I may be able to get the tool I need through a mechanic I know, in which case it may be worth doing. I don't think you can buy the tool and I don;t want to damage the brake removing it. Maybe a job for when it is too cold and frozen to ride in UK.
If not I will get a magic marker and colour it black. I did also think about using some green nail varnish but that will only add weight :roll:
Thanks again guys, knowing that someone has done it might make me have a go myself.
Enigma Echo
PostPosted: Thu Aug 05, 2010 11:33 am
No they were quite easy to remove. When I did it I placed the caliber in between 2 vices and unscrewed it with a wrench.
PostPosted: Thu Aug 05, 2010 2:31 pm
Do you know if I can buy the tool or will I have to get one made ?
Many thanks again,
Simon.
Enigma Echo
PostPosted: Fri Aug 06, 2010 11:34 am
Hi Simon.
I don´tknow if you can buy anywhere. I´ve just checked if I still had the drawing and the program on my computer because then would I have made one for you, but unfortunately everything has been deleted.
I´ll try to find it somewhere and if I find i´ll let you know.
Best regards
Morten Nørgaard
PostPosted: Fri Aug 06, 2010 2:03 pm
Many thanks Morten ... I would really like to get the correct tool as I don;t want to damage the brake caliper.
Thanks
Simon.
Enigma Echo
PostPosted: Fri Aug 06, 2010 11:27 pm
You can also use a really large allen key. Fits in well enough to extract/install because it is such a low torque piece.
Light. Strong. Cheap. Pick one.
PostPosted: Sat Aug 07, 2010 8:19 am
Cheers Benno, I'll give that a go.
Si.
Enigma Echo
PostPosted: Sun Aug 08, 2010 2:34 pm
Little update in case anyone is interested ... You can buy the tool for removing the star wrench bolt as sown above from http://r2-bike.com/Formula-R1-Bremssattelwerkzeug_1 and it looks like this.
Enigma Echo
PostPosted: Thu Dec 20, 2012 11:47 am
just about to ask the same question ....
the link to the tool below does not appear to be working - are you able to find it again?
It appears to be made from resin/plastic so I am wondering it is is possible to make ones own using the plug as the mould - use something like thin cling film then pack the recess with epoxy/chopped fibre glass mat.
PostPosted: Thu Dec 20, 2012 10:21 pm
Also interested in the tool. Got a pair of new blue caps but can't get the old ones out :(
/jonas l
PostPosted: Fri Dec 21, 2012 4:09 pm
I want one too! Anybody?
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 11 guests
There are no new unread posts for this topic. Anodized finish tarnished by sweat?
djm
Wed Sep 26, 2012 1:25 pm
wassertreter View the latest post
There are no new unread posts for this topic. 52cm CAAD10 Black Anodized
in Wanted
Nadler
Sun Jun 02, 2013 8:44 pm
Nadler View the latest post
There are no new unread posts for this topic. Help please - FSA compression plug
headwind816
Sun Mar 24, 2013 10:08 pm
DaveS View the latest post
There are no new unread posts for this topic. Sporttracks & Training load plug in
in Training
ACDC
Mon Feb 11, 2013 12:36 pm
darkblue08 View the latest post
There are no new unread posts for this topic. Attachment(s) cannondale sisl2 + new compression plug details
[ Go to page: 1 ... 4, 5, 6 ]
thisisatest
89
9895
Mon Feb 18, 2013 6:06 am
OwenJames View the latest post
It is currently Tue Jun 18, 2013 8:32 am
