Post new topic Reply to topic  [ 19 posts ]
Go to page 1, 2  Next
PostPosted: Mon Apr 26, 2010 9:37 pm
I've got a Litespeed Tanazi from 2005. It's too heavy. It's XTR - equipment all over and some other standard components delivered from Litespeed. My weight is almost 100 kg... so I can't heave the thinnest materials on everything.., I guess. I hope somebody can give me some advise. HTv from Norway.
PostPosted: Tue Apr 27, 2010 3:03 pm
What's your build list? I recently put together a Cervelo for a chap weighing 100 kilos. Still got the weight under 6kg!
My 2008 Scott Scale.
PostPosted: Wed Apr 28, 2010 7:11 am
I'm not good in the teknical descriptions, but I'll try. I guess U understand when U see the "names":
Gear, disc-breakes, wheels, chain: Shimano XTR
Gear...-11-27(32) and in front 46 on top
Stem: FSA XC140 Alloy
Stearing ??? BBB NCA Carbon Fiber
Seatpost: Thomson Elite, 40 cm I think. didn't "open" it
Seat: A guy is making a new seat for me in Carbon righet now. It's 80 gram
Barhands: BBB NCA Carbon
Grip: OURY
Fork: Pace 2,35 titanum Inside
The "rings holding the fork": Chris King "no thread set"
Eggbeaters titanium
Crank: FSA Carbon Pro ISIS drive
Frame: Litespeed Tanasi.
That's what i can find of spec. I hope it's possible to understand this. It's the first time I try to express these "things" in English and I even don't know all the expressions in norwegian....
PostPosted: Wed Apr 28, 2010 8:58 am
What are your tires? Size, brand name, ...
MTB - Van Nicholas Zion
Road - Van Nicholas Euros
PostPosted: Wed Apr 28, 2010 9:16 am
I'v left home now, but I think its Continental ..something.. 2.0 with tubes. I think the weight is about 300 grams
PostPosted: Wed Apr 28, 2010 11:59 am
Hm, and what is the total weight of your bike? What do you consider as "a heavy bike"?
You can save some weight replacing the stock XTR wheels (they are about 1.500g) for some custom built ones. Then use lighter disc brake rotors.
PostPosted: Wed Apr 28, 2010 12:03 pm
I think it's about 11 kg!!!
PostPosted: Wed Apr 28, 2010 1:01 pm
Not very light but :
8650 g :
9150 g :
8800 g :
Tanasi frame weight around 1400 g you can build a bike sub 9000 g :wink:
Post a picture and we can help you...
http://perso.orange.fr/courirenmontagne
PostPosted: Wed Apr 28, 2010 4:13 pm
11kg is too much. With the components spec you stated above it should be lighter than 10kg.
PostPosted: Thu May 27, 2010 10:16 am
Mine weight also 8,650 as my friend Coureur's one
build details
Litespeed Tanasi 2005 18"
Sid WC Black OEM + pushlock
Headset Chris King
Rewel Titanium seatpost (optimized)
Tune speedneedle saddle
Xtr Rear Derr. shadow SDS
XTR rapidfires
Aligator Ilink cable housing
BB30 Cannondale crankset SI SL + 128mm spindle (special cnc adapted) + Zipp Vuma Quad external bearings
Seven titanium stem
Use ATom 25.4 handlebar
Magura Marta SL special edition (initialiy OEM version for Scott Limitted)
Ashima 160 08 discs
Chis King ISO Hubs black
Cx-ray spokes
ZTR Alpine rims
Schwalbe RR (with liquid latex and yellow tape)
egg beater 4Ti
Tune Skewers Ac 16+17
King Ti Bottle cage
verified weight : 8kg650
7 Sola 8.100gr
PostPosted: Wed Jul 28, 2010 7:01 pm
hi, that sure is a nicely done bike. have you wired the spokes together where the meet? whats that all about? cheers
PostPosted: Wed Jul 28, 2010 7:24 pm
Thanks
Yes, the spokes are wired together (ligatured).
This is a technical mainly used in cyclo-cross. It avoids a spoke, when broken to disturb the wheel when turning. It has normally no effect on the wheel stiffness.
7 Sola 8.100gr
PostPosted: Thu Jul 29, 2010 11:16 am
Location: somewere floating between here and the other side
hi tortor..
i see u run a bb 30 in a normal bottombracket?
how does that work ?
are they all standard of the shelf parts?
thanks mick
PostPosted: Thu Jul 29, 2010 12:11 pm
michel2 wrote:
hi tortor..
thanks mick
You can purchase a special BSA-BB30 kit (including bearings, special spindle (cnc reworked) and zipp tool) at DR.Cannondale (germany)
http://www.cannondale-parts.de/epages/61764971.sf/en_US/?ObjectPath=/Shops/61764971/Products/KP094
Personnaly, I changed the bearing cups with original Zipp VumaQuad ones.
The systems works perfectly with a BSA Bottom bracket.
7 Sola 8.100gr
PostPosted: Thu Jul 29, 2010 12:30 pm
thanks..
i got a colnago and looking for a new cranckset for it...italian bb !(-:
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot] and 6 guests
There are no new unread posts for this topic. Attachment(s) Pulley bolts give me problems
Stockie
Sun Aug 19, 2012 10:21 am
Stockie View the latest post
There are no new unread posts for this topic. Can Cadence and Watt give Distance?
in Training
athletic
14
1148
Tue Aug 21, 2012 10:37 am
mrfish View the latest post
There are no new unread posts for this topic. I'll give a thumbs up to FSA customer service
rainbowstripes
Thu Jul 26, 2012 3:19 am
rainbowstripes View the latest post
There are no new unread posts for this topic. Attachment(s) My litespeed ghisallo
zoncolan08
Fri Oct 26, 2012 6:26 pm
dcj9 View the latest post
There are no new unread posts for this topic. New Litespeed CX art project
bigskyTi
Thu Nov 29, 2012 4:38 pm
trychle View the latest post
It is currently Sun May 26, 2013 8:33 am
