lightest centerlock rotors.
Composite World
by Composite World
i want to change my xtr 140g rotors with something lighter. any idea? thanks
grover
by grover
hope two-piece 6 bolt rotors with dt centrelock to 6 bolt adapters. should weigh 120grams for the setup. that's the lightest i know of.
cya, john.
hawkpower
by hawkpower
try this one
Tib
by Tib
Composite World requests a center lock rotor. You must add the weight of the DT adaptator !
Light center lock rotors does not exist ; there is only Shimano XTR. You must use an adaptator but I ognore its weight.
I use floating Hope rotors which weights only 87 grams, and there are full usable because of their steel rotor. But this is the 6 hole model, you will have to add the DT adaptator.
Never give up... never surrender !
Composite World
by Composite World
thanks for the help. i got enough with those superlightweight stuff, i wont go with stans. i am also thinking about hope. it seems like they will soon be everywhere. but if I use it with DT adapter, it will be 110, which is only 30g lighter. 60g of save for a lot of money. i think i will wait for my rotors to be worn or a light centerlock rotor. which one will be sooner? :)
besides, more part : more problem and less stiffness
mattpage
by mattpage
I think hope plans to bring out centrelock rotors for 2006.
TheRedMantra
by TheRedMantra
Its been a few years, any development?
rasputin
by rasputin
Newest XTR rotors are a bit lighter than previously as they now use a steel/aluminum/steel sandwich for the brake surface, but still weigh in at a relatively hefty 126 g. In fairness, CL hubs are lighter than their 6 hole equivalent (15 g in the case of DT 240s, claimed weights). In spite of this, the lightest option is still an adapter with an ultralight disc, however the XTR may be better in terms of heat dissipation and durability. So do as you see fit, I like those XTR rotors for peace of mind.
Mads Kock
by Mads Kock
Custom job from Mattias (EP) but pretty light and ÜBER cool:
BmanX
by BmanX
Mads wins.
I have been looking at a lighter CL set-up. The best that I can see at this time would be to get the KCNC center lock adaptor and match it up with the KCNC disc.
KCNC 160mm disc 73g
KCNC center lock adaptor 29/30g
102-103g total weight.
Still not as good as Mads modified version.
However, I would like to know the weight of the XTR center lock part without the bolts and disc itself. If this was heavier than say the KCNC adaptor then maybe Mattias could do something lighter using the adaptors.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
krzysiekmz
by krzysiekmz
There is a guy who could make 65g centerlock rotors out of Ti with aluminum spider. I think it was only a project, because of lack of interest.
Chris.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
Martin.F
by Martin.F
Those Hellöre looks awesome! Light weight, but the looks of the XTR's. Me likey :mrgreen:
02GF74
by 02GF74
those look XTR carrier - is the brake disc thinner in order to get the weight down? and/or made of soemting other than steel?
Mattias Hellöre
by Mattias Hellöre
One pro rider for Giant Rabobank asked me to make lighter brakediscs but to retain original look of XTR ,he´s sponsored by Shimano.
So I cutted out the disc part from 6al-4v titanium and used aluminum countersunk screws.
No more mods other than that, braking performance a bit lower than original but lighter.
I´ve tested some titanium discs in the current 2 years of development, all of them does have a bit lower friction compared to steel/stainless steel rotors.
But the upside is less weight.
Haven´t tried any coating yet.
/Mattias Hellöre.
Experimental Prototype
Mattias Hellöre
by Mattias Hellöre
krzysiekmz wrote:There is a guy who could make 65g centerlock rotors out of Ti with aluminum spider. I think it was only a project, because of lack of interest.
Chris.
It´s Tehan at MTBR.com you are talking about?, he seems have abandon the project, maybe of high manufacturing costs, the spline interface is not easy to do in a normal machine shop.
