It is currently Fri Aug 18, 2017 12:02 pm
Post new topic  Reply to topic  [ 15 posts ]
 Post subject: BB30 crankset
PostPosted: Thu Oct 22, 2009 7:45 pm
I'm searching for BB30 cranks for on my new Look 986.
Till now I only found :
- FSA K-force light
- Sram XX 2x10
can anyone else tell me with options I have besides these 2 :noidea:
It's not what you ride, it's how you ride it !
 Post subject: Re: BB30 crankset
PostPosted: Thu Oct 22, 2009 7:47 pm
Cannondale! Lightest of the other two you stated. And stiff.
Chris.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Fri Oct 23, 2009 2:51 am
Yes. Cannondale Hollowgram is probably your best choice for BB30. Lightning cranks would be nice too.
PostPosted: Fri Oct 23, 2009 1:36 pm
The K-Force is not the only BB30 offering from FSA... they also do a V-Drive and Afterburner BB30 crankset... both are heavy though.
Another option is Extralite E-bones in BB30...
ControlTech also have BB30 cranksets - the Rage OS (1020gr), Rage D (1015g) and Rage T (1050g)
Other than these, Cannondale, Lightning & SRAM the choice is limited... it defeats the point but you can always use a BB30 shim in the frame or run BB30 adaptors.
PostPosted: Fri Oct 23, 2009 4:30 pm
Yes,
I knew that FSA had more options, but like you said, I'm looking for a lighter option then those.
Thanks to bring on the other options ...
As for the adapters, I really would like to stick at BB30, what's the point of having a BB30 frameset and use the conventional system :noidea:
PostPosted: Fri Oct 23, 2009 4:46 pm
Agree totally!
PostPosted: Sat Oct 24, 2009 5:12 pm
easy choice, cannondle hollowgram SL crankset or the clavicula crankset :D
PostPosted: Sat Oct 24, 2009 7:47 pm
Clavicula doesn't come in BB30, only with adapters
PostPosted: Mon Oct 26, 2009 9:46 am
but Clavicula has 30mm axle
so can be "adapted" to a BB30
http://eliflap.it/
PostPosted: Mon Oct 26, 2009 4:48 pm
the hollowgram crank is also an FSA crank :lol:
I would go for the X.X!
PostPosted: Mon Oct 26, 2009 5:37 pm
Location: Physically in Montréal, but my mind is in the Pyrénées
Nope, FSA made the much less impressive Cannondale carbon SI cranks but the Hollowgram is designed and manufactured by Cannondale. The Hollowgram SL is still the crankset every other wished they could be. The threaded XX crankset turns out to be pretty heavy, heavier than claimed and far from impressive for being the latest and aimed as a light xc race crankset. The BB30 XX is heavier claimed than the Hollowgram but we can expect real world weight to be even more far off.
Dan Gerous
PostPosted: Wed Nov 04, 2009 11:20 pm
I went for the FSA K-force light (because I had the chance of making a great deal)
Bought the one with the red spider, because this was to flashy for me someone is changing the red spider into a white one (without transfers)
Should match perfectly with my white/black frame.
PostPosted: Thu Jun 12, 2014 8:32 pm
Any idea what the minimum Q factor is for the Look frame ? Would a Q156 mm fit ?
PostPosted: Fri Jun 13, 2014 4:07 am
If you've got the frame, just take some measurements. SRAM have a pretty comprehensive 'frame fit' guide on their website.
PostPosted: Mon Jul 21, 2014 5:01 pm
You can't go wrong with the Cannondale Hollowgram crankset... IMHO it's simply the best out there.
There are no new unread posts for this topic. Which Rotor crankset for Power2Max for BB30?
JunkyCollegeBiker18
13
644
Wed Mar 01, 2017 7:32 pm
jfranci3 View the latest post
There are no new unread posts for this topic. SRAM Etap crankset with BB30 compatible with Scott Addict SL (BB86)?
wootenlakeguy
Mon Feb 20, 2017 11:17 pm
grover View the latest post
There are no new unread posts for this topic. Investing in BB30 PM a bad idea?
AW84
30
1909
Wed Jun 14, 2017 3:58 am
AW84 View the latest post
There are no new unread posts for this topic. BB30 : Sram + fsa compatibilty?
alcatraz
Fri Jul 28, 2017 3:18 am
CycloTron View the latest post
There are no new unread posts for this topic. BB30 question plus new bike
Dennistwowheels
Sat Oct 29, 2016 12:58 pm
alcatraz View the latest post
Users browsing this forum: Yahoo [Bot] and 8 guests
