wondering how to make 3 speed to 2 speed shifter
crashman
by crashman
i know this sound crazy. i need to modify 3 speed XTR left shifter to the 2 speed coz im using 2 gear drive-train. Any expert modifying mechanics here? and also, i got alot of problem with xtr shifters. when going rough downhill, the shifter shift down by itself automatically and a result of chain sucks. :cry:
polaris
by polaris
If you're using a standard chainset and just dropping the granny ring you can just adjust the lower limit on your front mech and avoid changing into bottom on the shifter. No modifications necessary.
.....but it still has to work!
crashman
by crashman
polaris wrote:If you're using a standard chainset and just dropping the granny ring you can just adjust the lower limit on your front mech and avoid changing into bottom on the shifter. No modifications necessary.
doesnt it weight a bit heavier like 40g??? :D
polaris
by polaris
Doesn't what weigh more?
bladteth
by bladteth
Probably the screwdriver you need to adjust limit stop ;-)
Best regards,
Rado bladteth Rzeznicki
Joel
by Joel
It's just adjusting the bolt
Frankie - B
Administrator
by Frankie - B
Im riding this 2 x 9 setup for about 3 years now, and it works flawlessly!
With Shimano and with Sram.
