Post new topic Reply to topic  [ 65 posts ]
Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Aug 13, 2009 9:11 pm
I was able to get 1170 grams from a Tune Olympic II wheelset...Tune Prince/Princess, DT Aerolite and No Tubes ZTR Race 7000. I was tempted to swap the spokes to Pillar PST 1422 but I'm 80 Kg.
www.royalbicycles.com
PostPosted: Thu Aug 13, 2009 9:36 pm
Found some info on a french website, the inolite carbon rims x 2 came in at 510 grams.
So using them and something like the DT 190's or Ole's custom hubs will get you under 1kg no problem.
PostPosted: Thu Aug 13, 2009 9:45 pm
I have been promised rims at 250 or below for this project. :)
The problem with DT190 is very low flanges and you have to add 60+ grams for adapters for use lightweight discs.
I could make my wheels even lighter using Pillar 1422 all the way, but the rims would pull to the side during vertical g-forces, and make them less useful as something to actually race on. Using thicker spokes on the side with the highest tension gives more even spoke elongation, which again help keeps the rim staying centered in curves and during bumby terrain. My old wheelset with similar sproke configuration actually is more stable at speed off road than the one I had before, with 2.0/1.5/2.0 steel spokes all around, even though the latter was stiffer laterally.
Ole.
PostPosted: Thu Aug 13, 2009 9:57 pm
There are options on the adapters for disc, im running two i modded, and there are some out there at 9 grams a piece! Lot of work though.
PostPosted: Thu Aug 13, 2009 10:22 pm
I have ordered a few rims to Innolite and I received a few days ago a first delivery of 2 rims (28 holes).
I weighted each one at 250.0g.
The built was made with King Kong 28h / Aerolite / alu nipples 12mm.
The total weight is 1110g.
The rim is so light because there is no hook (like Lew ProVC1 I think).
So tubes seem to be required. Futhermore the risk of pinch flat is reduced.
But following advices of Innolite, I tried the front wheel in "notubes" with latex.
And it seems to work. I have only ride 90km with them, but no problem at the moment.
Concerning stiffness, it looks like the Olympic's stifness (with same hubs in 32h) in frontal and lateral, but with 100g less on each rim!
There are some others pictures of my wheels here: http://www.julmtb.com/forum/viewtopic.p ... c&start=60
Handbuilt MTB Wheels
PostPosted: Thu Aug 13, 2009 10:23 pm
9g each is very good! And safe? Anyhow, that's 18g extra, making the sub kilo 18g more difficult to reach. :)
Ole.
PostPosted: Fri Aug 14, 2009 9:29 am
Wow - that looks really sweet and white scrub rotors. Nice detail :-)
My blog
Scott Spark RC mtb
Scott Cx Team cross
PostPosted: Fri Aug 14, 2009 9:56 am
Friend of mine is very happy with his Innolites, weighs in at approx 1070g. No problem running them tubeless, it seems that the designer him self in running them like that. These wheels are on top on my wish list for christmas...
PostPosted: Tue Aug 18, 2009 7:46 pm
Ole.
can't wait to see your latest wheelset project completed
MTB components on scales: http://www.flickr.com/photos/culturespo ... 294427667/
PostPosted: Tue Aug 18, 2009 10:14 pm
Is it possible to run tires with these rims at the same amount of pressure as with Notubes?
Scott CR1 - 5,5 kg - done
Santa Cruz Blur Carbon - 8,9 kg - and tuning...
Body - 60 kg and tuning...
PostPosted: Tue Aug 18, 2009 11:32 pm
Meaning low pressure like 23-28 psi, right?
PostPosted: Thu Aug 20, 2009 1:07 am
Aye! I ride mine (Olympic rims) at 1,5 bar (front) and 1,7 (rear), that is 23 psi and 25 psi respectively.
PostPosted: Thu Aug 20, 2009 10:22 am
I ride my am classic and alex rims (which suck) in notubes configuration as well. I have to say I trust my ztr olympic rim more since the tire really hooks up into the rim, which isn't the case with AC and Alex. Another advantage of the olympics is the ease of pumping up a tire, I have no single problem inflating light tires on these rims. On the other hand, my other light rims are a big pain in the ass when it comes to inflate non-ust tires! (Even though I used a compressor and loads of soap). The latter problem is perhaps as well a problem of the innolite rims ??
"It's always your legs that count, but WW bikes make strong legs last longer!"
PostPosted: Wed Sep 02, 2009 8:06 pm
Project Sub Kilo is finshed! Or just started, really, as I have yet to ride the wheels. :mrgreen:
I spent the last few nights building them, with the rims weighing in at 239.2g and 241.2g.
28h front. 89g hub, wheel weight 434g
28h rear wheel, 170g hub, wheel weight 524g
:thumbup:
PostPosted: Wed Sep 02, 2009 8:25 pm
All I can say is WOW....Ole keep us posted on how those rims hold up. I myself may pull the trigger on a set. The only thing is that I need to be 100% sure it will work tubeless.
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Users browsing this forum: No registered users and 6 guests
There are no new unread posts for this topic. lightest disc caliper
cymans
11
2054
Fri Jul 20, 2012 3:06 pm
bones View the latest post
There are no new unread posts for this topic. Lightest Carbon/Aluminum Cross Disc Wheels?
in Cyclocross / Touring
morrisond
Fri Aug 24, 2012 1:12 am
Zen Cyclery View the latest post
There are no new unread posts for this topic. Lightest rims for 29er wheelset
in MTB
kavitator
7
1483
Fri Nov 16, 2012 9:38 pm
kavitator View the latest post
There are no new unread posts for this topic. lightest 29er carbon wheelset
in MTB
mcnbikes
Mon Jul 02, 2012 11:25 am
bikemaniack View the latest post
There are no new unread posts for this topic. FFWD'ish TT disc/4spoke clincher wheelset
Kasparz
Wed Mar 20, 2013 3:12 pm
Kasparz View the latest post
It is currently Sun May 26, 2013 1:57 am
