Post new topic Reply to topic  [ 10 posts ]
PostPosted: Thu Jun 25, 2009 12:20 am
Hi All !, has anyone ever installed the KCNC lightweight alloy chainring bolts on a XTR set up? I currently have a set of 5, and it looks like if I shorten the nutsert, I could get them to fit. I would have to order a second set though, but I wanted to see if anyone had any durability problems. :?:
PostPosted: Thu Jun 25, 2009 9:24 am
If the bolts are too long I guess you're using an XTR 960 crankset...? KCNC do make shorter chainring bolts for single rings... these do fit the XTR960. Cant comment on the durability though...
PostPosted: Thu Jun 25, 2009 1:28 pm
KCNC has two types of bolts...SPB004 Compatible with XTR FC-M970 Crank (8.5mm Bolt&6.5mm Nut) and the SPB003 Compatible with XTR FC-M960 Crank (6.5mm Bolt&4mm Nut) and KCNC TK1....so far we haven't had any type of issue with these.
www.royalbicycles.com
PostPosted: Mon Sep 14, 2009 4:50 am
Well, I can personally recommend NOT to buy the wrong size for you crankset. I filed and ground down my longer KCNC alloy bolts and almost ruined them. I was able to shorten them with a grinding wheel then filing them smooth. But I had a hard time holding them in a pair of vice grips with rubber tips. I ended up scarring some of the sides. If they weren't so darn expensive I would have replaced them with the proper size.
PostPosted: Fri Dec 18, 2009 2:20 am
Where can I buy these bolts by KCNC? I need to add some missing bolts to my outter chainring (XTR M970).
Thanks.
PostPosted: Fri Dec 18, 2009 10:19 am
Any clue where you are from?
Cervelo R5 VWD 5637g/12.43lb
Cannyon Ultimate slx 5592g/12.33lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Fri Dec 18, 2009 9:12 pm
i purchased a set on ebay back in august from yan_kelly, they seem to be holding up well & kept their torque
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 3D1&_rdc=1
set was in red for the mrs's XTR M970 + triple Rotor Q-Rings, no probs installing them but was extra cautious winding up the threads
MTB components on scales: http://www.flickr.com/photos/culturespo ... 294427667/
PostPosted: Fri Dec 18, 2009 11:29 pm
I haven“t had any issue with them since february...http://img194.imageshack.us/i/dscn5586c.jpg
http://img194.imageshack.us/img194/4444/dscn5586c.jpg
Edited. The pics were just a wee bit larger than permitted on the forum. :wink: Merry x-mas to all, by the way! Powerful Pete.
Rider on the storm...
PostPosted: Thu Dec 24, 2009 11:24 am
Had the bolts in my XTR crank.
Lost 2 bolts in 4 months.. :?
PostPosted: Wed Feb 06, 2013 12:10 pm
I want to put some colour on my XTR960 JJ mod. cranks. What bolts are strongest KCNC or TISO?
Users browsing this forum: maddog 2, yourdaguy and 17 guests
There are no new unread posts for this topic. alloy bolts sram red 2013
c90sx
Fri Feb 01, 2013 1:26 pm
stevec1975 View the latest post
There are no new unread posts for this topic. ti anti sieze grease required for ti bolts on alloy stem?
in MTB
nrsnow
7
902
Tue Oct 09, 2012 12:44 pm
miceden View the latest post
There are no new unread posts for this topic. +/- 4 deg alloy stem?
AllAboutTheEngine
Thu Dec 13, 2012 9:37 pm
NGMN View the latest post
There are no new unread posts for this topic. WTB: 3T Ergonova (alloy)
in Wanted
nspace
Fri Mar 01, 2013 2:58 pm
nspace View the latest post
There are no new unread posts for this topic. Alloy clincher rim review
madcow
30
2930
Tue Jan 29, 2013 12:22 pm
MajorMantra View the latest post
It is currently Wed May 22, 2013 9:37 pm
