lightest mountain tubes with 48 or 60 mm presta valve
flat_chipmunk
by flat_chipmunk
I just switched to disc specific rims with a deep "V" profile. This leaves little room to get a pump on the valve. Anyone know what are the lightest mountain tubes with longer than average 48 or 60 mm presta valves? (I already checked out the weight list but it does not specify valve length on most tubes)
Thanks!
flat chipmunk (formerly known as squished chipmunk or chipmunk jerky)
nikh
by nikh
What rims are they? Have you thought about going tubeless?
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
Joel
by Joel
You can use a valve extension :idea:
