RockShox Psylo SL 2001 detailed weights
bladteth
by bladteth
Hi,
RockShox Psylo SL 2001 detailed weights:
stanchions, crown and 235 mm long steerer - 741 g
sliders and brace - 492 g
coil spring (red) w/ protective sheath - 221 g
compression damper assembly - 72 g
rebound damper assembly w/ adjuster knob - 57 g
Pure tube w/ plastic ends - 53 g
VariTravel rod assembly - 41 g
preload cap - 28 g
dust seals - 22 g
brake bosses - 20 g
shaft bolts - 18 g
Climb-It control cap w/ plastic rod - 10 g
circlips - 9 g
oil - ca. 86 g
total - 1870 g
Best regards,
Rado bladteth Rzeznicki
