It is currently Mon Dec 18, 2017 6:05 pm
Post new topic  Reply to topic  [ 53 posts ]  Go to page 1 2 3 4 Next
 Post subject: Tune Superscharf Body
PostPosted: Wed Feb 25, 2009 8:48 pm
Hi,
I found some threads on this but no real answers... My spockets (SRAM) seem to dig their way into the hubs body a little. Any way to get rid of this problem (different way mounting it)?
I also read something about a titanium body, does Tune still distribute these (under warranty?)?
Any information is welcome :)
 Post subject:
PostPosted: Wed Feb 25, 2009 9:36 pm
yes Tune produced titanium freewhel body
Tune
Merlin XLM
Litespeed Siena
Other bikes
 Post subject:
 Post subject:
PostPosted: Wed Feb 25, 2009 10:23 pm
A lighter and cheaper option is to use the American classic clip/pin set between your cassette and the aluminum freehub body. They retail for about $15 for the set.
I should note that this is designed for Shimano road cassettes and I haven't tried this with a Sram cassette, but don't see any reason why it wouldn't work with Sram.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
 Post subject:
PostPosted: Thu Feb 26, 2009 12:16 am
Got any pictures of these?
naked 3po, the first weight weenie.
 Post subject:
PostPosted: Thu Feb 26, 2009 1:32 am
These clips are for 10 speed spaced cassettes only. They won't work with 9 speed cassettes. Unless ofcourse you are running some sort of 10 speed setup with road/bar mount shifters meant for touring/comfort bikes.
PostPosted: Thu Feb 26, 2009 3:01 am
I have SRAM PG990 cassette and Extralite hub and I put 1.27mm x 0.55mm x width_of_cassette thin sticks (actually flattened out very hard carpenter staple) between every freehub spline and cassette so that force is not concentrated on small area of one sprocket. It's cheap trick and the weight gain is only 1-2g. After 3000km freehub is still like new.
Merida Carbon FLX Multivan
 Post subject:
PostPosted: Thu Feb 26, 2009 3:28 am
Pictures of this please and where do you get and what size "carpenter Staples"?
For certain parts stiffer is more important than lighter.
 Post subject:
PostPosted: Thu Feb 26, 2009 9:15 am
I'll take some pics tonight.
 Post subject:
PostPosted: Fri Feb 27, 2009 12:08 am
Alchemy Bicycle Works has the Ti cassette for Tune hubs...I think is around $95
www.royalbicycles.com
 Post subject:
PostPosted: Fri Feb 27, 2009 2:49 am
They are made for Black & Decker staple gun.
File comment: size
File comment: carpenter staples
File comment: flattened out staples
File comment: after 3000km!!!
File comment: installed sticks
 Post subject:
PostPosted: Fri Feb 27, 2009 3:29 am
You win. Even with measured lengths for us to see!!!!!!!!
I was using tin can shavings in between the teeth to make the hub fit tight, however it didn't save the aluminum hub from gouging. That's awesome. I'm headed to home depot!!!
I take it that you just slide them down there, right?
 Post subject:
PostPosted: Fri Feb 27, 2009 3:35 am
Thanks! This is a brilliant idea, I never would have thought there was room.
 Post subject:
PostPosted: Fri Feb 27, 2009 9:26 pm
So the stapler fires different lengths. If you use 14mm length, it is 0.55 inches. Closest depth staple would be 9/16 inches for imperial users which gives 0.56 mm. Thanks!!
 Post subject:
PostPosted: Sat Feb 28, 2009 1:45 am
14 mm is 9/16 in US. I went to the hardware store today and they come in several thicknesses. I opened all the boxes of 14mm and 9/16 and bought the thinnest ones. They were ACE Hardware brand and were $4 for a thousand. Then when I got home I micrometered them and they were pretty close to 1.27mm.
I hope I can get them in there.
 Post subject:
PostPosted: Sat Feb 28, 2009 3:27 am
You're Brilliant! :idea:
 Post subject:
There are no new unread posts for this topic. Exustar pedal body parts?
loudtiger
Sun Apr 23, 2017 1:12 pm
alcatraz View the latest post
There are no new unread posts for this topic. Bora Ultra 35m - Hub Body Wobble
in Everything wheels
cincardo
Mon Mar 13, 2017 8:51 pm
cincardo View the latest post
There are no new unread posts for this topic. Bora : issues with cassette body, again...
Delorre
Fri Jun 09, 2017 9:37 pm
metalplease View the latest post
There are no new unread posts for this topic. Trouble pulling driver body off on Zipp 404 hub
Shrike
Wed Jul 05, 2017 10:11 am
Shrike View the latest post
There are no new unread posts for this topic. A Review: Body-Customized Meld Saddles
antonioiglesius
33
5598
Fri Nov 03, 2017 5:35 am
random101 View the latest post
Users browsing this forum: No registered users and 5 guests
