Stan's (notubes.com) alum disc rotors
flat_chipmunk
by flat_chipmunk
I am converting from V-brakes to disc. I am thinking of buying Stan's 252 gram Formula B4SL kit but am concerned about his warning that his rotors may squeal more than stainless rotors-especially when wet. Before buying I wonder if anyone has used Stan's alum disc rotors? Do they indeed squeal when dry too?
Any other brand suggestions instead?
Thanks!
DanBB
by DanBB
Im sure Nikh will be able to offer some advice on that one, since he has just brought the alu rotars....when he see's your msg that is :D
nikh
by nikh
Just got back from a trip abroad so I haven't had the time to bleed the brakes.
As soon as I do I'll post a report on them.
From what I've heard they are just as good as the Formula ones.
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
suprduprlyt
by suprduprlyt
Hey,
I have used Stan's aluminum rotors for about a year and a half. They do squeal-not all the time and not real loud, but most of the time. The pads necessary are softer, too. They don't have the "bite" of semi-metallic pads, and are nothing like the full sintered pads.
That said, they are plenty powerful for most people, most of the time. I'm usually happy with them, until I go on some epic ride in WV or PA with long, technical descents.
Greg
nikh
by nikh
Thats good to know, thank you.
