Scott Spark replacment shock?
ww4
by ww4
check this out a remote control luck-out for FOX PR23 shock custom made by Australia seller, seach in ebay for "Fox Float Rear Rear Shock Remote Lockout Kit".
jmartpr
by jmartpr
That is just a remote for switching from ProPedal to Open...but not to lock 100% the shock.
GrahamB
by GrahamB
Tiffster wrote:I think you'd get a loooooong debat about Fox being the best - certainly from what ive read on some forums reliability of them is awefull, seals going, stancions wearing, bushings having play in them from new to name but a few..
The main thing that pisses me off re Fox is that they don't give out any info to help you service them yourself. Everything has to go via an authorized dealer. Rock Shox, in contrast, tell all...
Graham
beatnik
by beatnik
I ride my bike for 4 years without needing service even in my Triad or RLT. They don´t loose air in the whole year.
Biomechanical spreadsheet. Sizing&Fitting.
http://weightweenies.starbike.com/forum ... 8e319d185b
crazyeddie
by crazyeddie
i have an monarch 4.2 on my spark. i'm sub 70kg, and with original setup (retail version "B") there is too less damping. with 10wt oil instead of 7,5wt, it works, but perhaps i will change to 12,5wt. i build a custom remote adapter and use one poploc for fork and rear shock. i will post pics when i get my pushloc and the problem solvers cable doubler 1:2.
eliflap-scalpel
by eliflap-scalpel
eye to eye distance of shock ?
which size i must search to replace the stock SPARK shock ?
http://eliflap.it/
jmartpr
by jmartpr
165mm
Tiffster
by Tiffster
@ crazyeddie
Any pics of that ?
I like my Monarch 4.2 with "B" tunning im 90kg too. But i did have it fiddled with when new so maybe its been improved i dunno
eliflap-scalpel
by eliflap-scalpel
jmartpr wrote:165mm
thanksssss
http://eliflap.it/
apLe
by apLe
Hello guys! I'm considering buying a spark and I would like to replace the original shock with rp23 BUT I've heard from my friend about an issue. When replacing the shock you need special bushings for rp23 to fit it to the spark frame - OK. However, I'm not sure it it's true, the original bushings/original shock has got "bearings inside" which allows the shock to move not only up-down but also left-right. Is it true? If yes, isn't dangerous for the frame to install rp23 with "rigid" bushings? Thanks for any piece of advice!
18' R5 coming soon...
jmartpr
by jmartpr
if you use alloy bushings like the ones sold by Fox you will be Ok,. These allow some horizontal movement but I doubt you would want some lateral movement at all on the suspension.
apLe
by apLe
The thing is though, I haven't seen it, touch it etc. So I don't know what my friend was talking about?! He said that original DT Nude has got 'bushings with bearings'?! allowing shock to move. Replacing with FOX and original FOX bushings made the shock 'rigid' in the frame. He got scared about potential frame destruction and he resigned. Now I'm facing the same problem because I don't want this bike with DT Nude. Either I can replace it with Fox or I will not simply buy the bike.
adgem1
by adgem1
I have been using a Fox rp23 with bushings supplied for 12 months on my Spark ,no problems at all ,also had Push conversion done that is awsome,any more questions ?
Scott spark LTD,Kinesis -crosslight PRO 5,kinesis evo,TK,Orbea alma,Canyon Ultimate cf
jmartpr
by jmartpr
You don't have to worry about anything.....I'm on my second Spark with RP23 with no problems so far.
