Stans Tubeless Rim 355g now available
- Xterra Racer
- Contact:
What happened to the name the rim contest that Stan was running. After entries were do I never saw anything else posted on his web site.
Xterra Racer wrote:What happened to the name the rim contest that Stan was running. After entries were do I never saw anything else posted on his web site.
No idea man, I couldn't even figure out what rim it was.
I was thinking it was Mavic something?
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
- Xterra Racer
- Contact:
Heard that the rim was at Stan's booth at interbike. Also heard that the rim does not have eyelets.
I don't know of anyone else out there doing rims now-a-days with out eyelets. There is a reason everyone else uses them....because if you don't use them your spokes have a tendency to just pull out.
Just beware if you order these things, you might want to check with him on it (especially because the sets start at over $500).
- Xterra Racer
- Contact:
Got the info from Stan. Indeed the new rims will not have eyelets. His claim for the reason is to save 10 grams.
So all you wheel experts out there....what does this mean for performance. Joel pointed out that the use of eyelets allows for higher spoke tensions. How durable would these rims be without the eyelets. If I bought a set, would I be replacing spokes every other ride??
- Xterra Racer
- Contact:
Stans new rim is using Aluminum nipples.
No offence Ger - but I'm looking for someone that knows wheel building rather than just quoting something that was heard through the grape vine.
Bottom line here folks....if these wheels are going to be hold up they will be 40 grams per wheel lighter than anything else out there. I really want to find out all the details.
You probably wouldn't have too many problems with the wheels unless you're riding them very hard.
'Potentially' it could cause serious problems though, as the eyelets help spread the spoke tension evenly around the the hole in the rim. Without them not only do you break more spokes you also compromise the structural integrity of the rim.
....for 10g?
....for 10g?
.....but it still has to work!
- Xterra Racer
- Contact:
So question of the day is can you retrofit a rim with eyelets??
The 10gram savings was Stan's only excuse not to use the eyelets. Seemed pretty lame to me.
- Similar Topics
- Replies
- Views
- Last post
Tubeless with non-tubeless tires? Anyone tried it? How did it go?
by alcatraz » Wed Aug 09, 2017 3:44 pm » in Everything wheels - 30 Replies
- 2251 Views
Last post by Marin
Thu Sep 07, 2017 6:06 am
- 2 Replies
- 779 Views
Last post by boysa
Tue Sep 19, 2017 3:40 am
- 32 Replies
- 2194 Views
Last post by Geoff
Mon May 08, 2017 2:18 pm
- 14 Replies
- 376 Views
Last post by NovemberDave
Wed Mar 07, 2018 3:21 pm
Tubeless options for CX racing
by wheelzqc » Tue Jul 25, 2017 12:39 pm » in Cyclocross / Gravel / Touring - 14 Replies
- 1361 Views
Last post by stormur
Sun Jan 14, 2018 8:13 pm
