Post new topic Reply to topic  [ 43 posts ]
Go to page 1, 2, 3  Next
PostPosted: Fri Dec 03, 2004 11:34 pm
Some time ago I posted "How to tune SID World Cup" on WW. I recieved some replies amog which Nino's seemed to be the most interesting. He scored 1068g :shock: using some parts from SID Race 2001. I had such SID and decided to tune my new World Cup in similar way in the future. I purchased SID WC 2005 last month and tuned it to 1098,54g. This is how I done it:
My new SID WC 2005
On the scale w/out poploc lever. NOTE claimed (RockShox) 1299g
and w/poploc :cry: That's surely NOT light weight fork.
I tuned original WC's legs because those of SID Race 2001 had bushings worn out
First I file the disc brake holder off
it saved 10,53g
Next step was removing stock painting and stickers and sanding the legs. weight saving: 7,27g
New painting and custom made :D stckers +3,48g
From 2002 RockShox does not use cartridges as damping system any more. The 2005 PureDelite system is really heavy :cry:
PureDelite works more effective than cartridge. However you don't need it when you use your fork mainly to race. The cartridge from SID Race 2001 works great. It's also THE LIGHTEST damping system used by RockShox. Replacing PureDelite by cartridge saves 160,25g :!: :!: :shock:
NOTE: it's non-servicable and non-adjustable cartridge. You don't need rebound adjuster any more :D . Weight saving: 3,5569g :!:
Replacing new alu air cap by the old one saves 3,9253g :!:
Final effect: tuned SID WC 2005 UL project. Real weight: 1098,54g :D
And some pics of my fork:
The lightest option is to use 2001 Race lower legs:
Blue painting has thick layer; removing and sanding it saves 20,86g :!:
With this legs (add 3g for new painting and stickers) SID WC will weigh superb 1081,72g
thanx to Marek Tyniec :D and Wojciech 'Woytex' Frackowiak for help :!:
 Post subject:
PostPosted: Fri Dec 03, 2004 11:42 pm
WOW! :shock: Compliments!
 Post subject:
PostPosted: Sat Dec 04, 2004 1:28 am
pretty good results. congratulations. :thumbup:
but for me a fork without lockout dont work... :(
hey
ho
lets go!
 Post subject: nice posting
PostPosted: Sat Dec 04, 2004 1:49 am
It is one the best postings I've seen. Pretty informative and well documented with photos and a real nice scale.
Cheers on you for this one. 8)
 Post subject:
PostPosted: Sat Dec 04, 2004 2:31 am
superb post.
i specially liked the custom stickers and the stronger lowers.
is nino sid lockable? why did you removed the regulators for only 4grs?
thanks
Happy trails !!!!!
 Post subject:
PostPosted: Sat Dec 04, 2004 10:20 am
No, it's not. In my opinion it's impossible to get under 1100g without removing lockout. First I tried not to remove lockout replacing only pop loc by the plastic climb-it control adjuster (from SID Race). Tuned SID WC 2005 in such way comes with 1289,68g. :? See pics below. It was too much so I decided not to use lockout any more. You don't need to use lockout when you weigh not too much. My old SID Race 2001 worked great. I'm sure my new WC 2005 will also.
which regulators are you talikng about?
 Post subject:
PostPosted: Sat Dec 04, 2004 2:03 pm
hi
can u post a picture of the screw fixing the low damper rod on the lower legs?
i think this huge screw is made of steel...
felix
 Post subject:
PostPosted: Sat Dec 04, 2004 2:17 pm
felixthewolf wrote:
hi
felix
you're right. this bolt is made of steel. it's standard M6x15mm so it colud be replaced by Ti one. thanx for good idea :wink:
 Post subject: hi
PostPosted: Sat Dec 04, 2004 5:04 pm
on my SID SL 02 (one of the heavy ones) this bold was replaced by an AL-bold normaly used to close the hole if u removed the brakestud.
i think, this screw can be replaced by an Al-bolt, there were no heavy loads on.
felix
P.S. this could be usefull for all SID SL 02 user they dont need to twist on their rebound all the time, it will save 11gr. ;)
 Post subject:
PostPosted: Sun Dec 05, 2004 4:13 pm
what painting weight only 3 gramms?
is there a damping system in the rigt side of the fork? at the left are the positiv and negativ air?
-> i have a sid sl `99 and a sid sl `03 the lightest cobination is 1170g (with: ti canti studs/ stock paint, without: lock out/ disk brake stud)
Pedä
 Post subject:
PostPosted: Sun Dec 05, 2004 4:53 pm
It's acryl spray which gives very thin layer which is rather short lasting :(
The damping system is in THE LEFT (having the fork face to face) side of the fork, and at THE RIGHT are positiv and negativ air.
 Post subject:
PostPosted: Sun Dec 05, 2004 4:57 pm
thanks :D
what is the weight of the carbon part with the upper tubes?
what is the weight of the cap, without the `ventil`(i mean the hole for filling with air) nad wher can i get such a cap?
Pedä
 Post subject:
PostPosted: Sun Dec 05, 2004 6:39 pm
It's ca. 736g. I mean carbon steerer integrated w/upper tubes and with internals (left: non-adjustable cartridge; right: positive and negative air). I do not know the weigh of the separated carbon steerer w/upper tubes because I removed internals only from left upper tube. Comparing to Nino's post on http://forums.mtbr.com/showthread.php?t ... id+project it should be around 483g
Do you mean THIS top cap showed on the pic?
Unfortunately I did not weigh it :(
 Post subject:
PostPosted: Mon Dec 06, 2004 2:02 pm
i have seen the weight in ninos post... thanks!
yes i mean this cap, but it is not so important... i have to save weight with carbon first... than my sid should weight about 1120g
Pedä
 Post subject:
PostPosted: Mon Dec 06, 2004 2:25 pm
doctoree how did you made those custom stickers?
can you send a pic of your bike with the new fork? it must look good.
what´s the new total weight?
thanks
Happy trails !!!!!
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: No registered users and 15 guests
There are no new unread posts for this topic. Eurus 2005 hub service question
Greg66
Wed Sep 26, 2012 10:22 pm
fdegrove View the latest post
There are no new unread posts for this topic. Moving On: 2005 BMC ProMachine to 2012 Cannondale EVO
bluhorizan
Sun Jul 29, 2012 9:48 pm
reggiebaseball View the latest post
There are no new unread posts for this topic. 2005 Scott Cr1 team issue reach and stack for 54 frame
digitalnorbs
Thu Jul 26, 2012 8:56 pm
There are no new unread posts for this topic. Attachment(s) GURU photon for my world champion friend
benrosa
15
2569
Wed Jan 16, 2013 4:50 am
irongatsby View the latest post
It is currently Thu Jun 20, 2013 11:33 am
