Post new topic Reply to topic  [ 20 posts ]
Go to page 1, 2  Next
PostPosted: Fri Nov 02, 2007 6:13 pm
with my new Pedal force MTB build i want to run a 1x9 set-up. 32T in the front and a 11-34 cassette. I will have no front derailleur of course so to insure the chain stays on I heard that this N-Gear chain device works well. The question i have is....does this device mount in the place where the front derailleur would go? Is the metal plate adjustable in and out to correctly fit snug up against the single ring? Anyone use this device with a single ring and no front derailleur? feedback?
to go faster....just pedal harder!
PostPosted: Fri Nov 02, 2007 6:55 pm
Yes it mounts in place of the front derailleur, and yes you can adjust it in and out. I use it on my single ring cyclocross bike. Lots of training and racing, never dropped the chain.
 Post subject:
PostPosted: Fri Nov 02, 2007 7:27 pm
sweet!!! I just bought one
 Post subject:
PostPosted: Fri Nov 02, 2007 8:45 pm
Does anyone know a European source for N-Gear?
 Post subject:
PostPosted: Sat Nov 03, 2007 2:33 am
i am running a 1x9 on my pedal force. i have had some trouble getting a good chain line and not dropping my chain. right now i'm trying the rohloff chain guide cc. its working ok. i still need to adjust my chainline slightly. but i might need to try this n gear thing.
Michael
 Post subject: Highly Recommended
PostPosted: Mon Nov 05, 2007 4:29 pm
I can't speak highly enough about this choice. I have tried many other options before using the n'gear, including what I thought were some good homemade options, but this is the best working and lightest setup I've used so far. I have never dropped a chain with the n'gear. I am running a 1X9 32t front with an 11-34 cassette in the rear.
 Post subject:
PostPosted: Mon Nov 05, 2007 10:18 pm
johnnysuede............
do you think you still need the Spot chain gaurd ring or would the chain still stay on without it? I want to run the same set-up you have but without the Spot gaurd ring.
 Post subject:
PostPosted: Mon Nov 05, 2007 11:04 pm
very nice. even if your running 2x9, its a great item.
whats the weight of these?
 Post subject:
PostPosted: Mon Nov 05, 2007 11:59 pm
30 grams
 Post subject:
PostPosted: Tue Nov 06, 2007 4:25 am
I think it would. The chainline on my setup leans more to the inside. In other words my chainline is straight on the third cog from smallest, making the other six angled progressivly more. Before the n'gear my chain always dropped to the inside. I use the guard more for log rollovers than anything else. I love the amount of clearance a 1X9 (or single speed) setup gives you, but I still hit the ring every so often.
 Post subject:
PostPosted: Tue Nov 06, 2007 2:36 pm
Here is my setup, works really well. The guide is 22g, hoping to make it a bit lighter.
 Post subject:
PostPosted: Thu Nov 08, 2007 7:28 pm
just got my NGear today, very nice. I want to replace the heavy steel bolt with an alloy one.....anyone know what size that bolt is....length and head size?
 Post subject:
PostPosted: Thu Dec 06, 2007 12:12 am
got a Ngear for my new pedal Force frame and the frame is so thick at the spot where the Ngear mounts, that i need a longer bolt. Is the bolt that comes with the Ngear a M4 size?
 Post subject:
PostPosted: Thu Dec 06, 2007 1:27 am
Just measure it with a ruler.
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
 Post subject:
PostPosted: Thu Dec 06, 2007 1:56 am
I know what length i need, i just need to know the bolt thickness............which is either a M4 or M5
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
Users browsing this forum: TheRookie and 13 guests
There are no new unread posts for this topic. KMC 11-speed chain wear question
goldmine848
33
1339
Tue Sep 11, 2012 10:05 pm
Calnago View the latest post
There are no new unread posts for this topic. Front derailleur "device" to use a bottom pull FD on CX
in Cyclocross / Touring
LouisN
Sat Feb 23, 2013 3:44 am
LouisN View the latest post
There are no new unread posts for this topic. Risk using seatpost over stop line
Helmutti
21
1117
Sat Jan 12, 2013 3:28 am
Scott! View the latest post
There are no new unread posts for this topic. Tubular sealant - Michelin Stop&Go?
E777L
9
838
Tue Dec 04, 2012 5:30 pm
fdegrove View the latest post
There are no new unread posts for this topic. Attachment(s) SWISS STOP for Ultegra 6700
project3
Tue Aug 14, 2012 6:59 am
project3 View the latest post
It is currently Sat May 25, 2013 12:53 pm
