The lightest front derailleur for MTB ?
i've got on my XtC Composite a front derailleur XTR M960 04, which is about 148 grams. it's too much for me !
have you an idea for a lightest ? Dura Ace ? i need a 34,9 mm, and i'm in 22/32/44 for my crankset...
thanks !
thanks !
Never give up... never surrender !
DA would probably be the lightest, provided that the XtC Composite frame takes a bottompull FD...
I'm using an older M950 XTR FD (ø34,9mm) - it's 113 grams with alu cablepinch- and clampbolt.
While this thread is here, could someone explain the difference between braze-on and clamp for front derailler?
A braze-on DA FD-7800 is claimed at 74g!!!
How do the options stack up?
Shimano DA Vs Campagnolo?
I have a spec M5 HT. Geometry is 34.9 clamp and Bottom pull.
I'm currently running an XT front derailler. Could I use the existing clamp and attach a lighter weight triple road derailler?
ARAMID front derailleur Clamb
- Weight is 31,8mm 11g
- Weight is 34,9mm 13g
The lightest: BTP For the rest I don't know, but I think clamp-on derailleurs are lighter (one bolt less) and you could shave the clamp a bit.
Braze-on plus BTP clamp could be the lightest possible, but it's a carbon clamp.
