Post new topic Reply to topic  [ 69 posts ]
Go to page Previous  1, 2, 3, 4, 5
 Post subject:
PostPosted: Mon Apr 23, 2007 11:40 am
411 grams ready to run but I will squeeze out a little more, want to see 399 gr.
Thanks for the BB tips, I will widen my search a more, priority 1 is low weight, durability is second because I can´t use all my 5 bikes everyday.
Experimental Prototype
 Post subject:
PostPosted: Mon Apr 23, 2007 12:41 pm
if I were you I would go for dura-ace bb. mine weights 171 g.
great work!
I used to do a little but a little wouldn't do it
 Post subject:
PostPosted: Mon Apr 23, 2007 12:47 pm
great work!
Great tip, 171 grams are not bad, what´s the thread I have on my MTB?
Roadies uses a little different threads?
I need 73-113 or something like that.
 Post subject:
PostPosted: Mon Apr 23, 2007 2:44 pm
dura-ace was made in two versions. one is for wide bb shell /70mm i think/ and has italian thread /won't work with mtb frame/. second one, which i have is 68mm wide and has the kind of thread that all mtb bb's have.
how wide is your bb shell?
 Post subject:
PostPosted: Mon Apr 23, 2007 4:54 pm
Unfornutately I drive GT´s with 73mm shells them all.
BUT I have little plans in my head that involves 952 axles and other cups for sealed bearings like them in integrated cranksets.
I managed to get the crankset to 401 grams.
Not too bad for adesign that´s nearly 10 years old.
They´re stiff too in standard form, in tuned form quite stiff I think.
PostPosted: Fri Jul 13, 2012 12:59 pm
I don't know is this a good place to ask,but i have a question about XTR 952 cranks and BB for them. I have one of those and BB-M5500. It's a road BB and it should work with those cranks,but i didn't work good. Left crank arm is moving a little bit when I push harder and sounds horrible. Whats the good BB alternative for that crank( XTR 95x BB,or some other road one)??
Thanks
Martin
PostPosted: Fri Jul 13, 2012 2:45 pm
Can you repost the last photos as they have disappered!
"I could have done this job myself in five minutes, but as things turned out I had to spend two days trying to find out why it had taken someone else three weeks to do it wrong."
PostPosted: Sat Jul 14, 2012 6:57 pm
I also ground off the sharp edges on my M952 cranks. I'm running 1x9 with a 30t from HBC and an Ultegra BB.
Weight and stiffness are excellent for the $$.
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Sat Jul 21, 2012 5:10 pm
I have XTR 952 Crank arms and i would like to buy Dura Ace BB,is this a good choice?? Will be working good??
Thanks
Martin
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5
Users browsing this forum: psbot [Picsearch] and 6 guests
There are no new unread posts for this topic. SRM for THM 3M cranks??
civdic
7
735
Tue Dec 04, 2012 9:47 pm
tetonrider View the latest post
There are no new unread posts for this topic. Campag 52/36 cranks
markyboy
Tue Jun 05, 2012 4:29 pm
Willier View the latest post
There are no new unread posts for this topic. Rideabike cranks?
verycreativeusername
Sun Dec 09, 2012 12:51 am
btompkins0112 View the latest post
There are no new unread posts for this topic. Non Shimano Di2 Cranks
Plugger14
20
1869
Fri Oct 12, 2012 3:42 pm
row618 View the latest post
There are no new unread posts for this topic. 24T Chainring for XX Cranks???
in MTB
rouleur1
13
1496
Tue Dec 11, 2012 5:19 am
UpFromOne View the latest post
It is currently Fri May 24, 2013 5:12 pm
