Tips for the serious weight weenies only...
Hi,
i'm new here in the forum. I'm danish so don't expect any proper english.
I've read a lot about weight saving tips in the forum, and as a thanks I'll post some extra not seen tips here...
You know, the best weightsavings, are those that don't cost ya.
1. If you've god large enough Hands - remove the screws for play from your STI / brakelevers.
2. Remove gear display from your STI / shiftlevers.
3. Remove the rubber-couting that is on some cable-screws on the rear deraillerus.
4. Remove the springs from your skewers.
5. Remove any Stickers you don't like / need.
6. Remove the holding nut and the plastic coating on the tubevalves.
7. For the very serious: Screw out your your cableadjusters and remove the sping and the plastic. Once properly installed you don't need to easily adjust them on the ride anymore.
8. For your cable-ends. Use plastic-glue instead of anything else. It holds the cables together top, and weights lessest.
Thats it for now - I'll see if I come up with some of my better tips too.
Principia MSLe Pro 9543g
If you accidently had to, could your bike take a smaller downhill ?
Me stupid forgot to mention....
I have designed and machined some new Cable-adjusters without the sping and the plastic.
Material is Aluminium 7075. Eloxiert you will get any Color you'd like...
I've calculated the thickness to be strong enough for both shifter and brakes.
If you want to, then i could post some pictures and then perhaps you could make them yourself too...
Glad to help.
One extra little Tipp because of my stupidness:
For those with an Klein and full brake-cables (inner and outer) inside the frame i have designed some "caps" to fit into the Frameholes, this will both shorten the outer cable length and secondly you'll get extra stregth because of the lesser cable that can be pressed together.
I could post some pictures of those too...
But this is really it for now then.
Glad to help.
To further the tip on cable ends... why not use electrical tape: just as light and a lot easirer to use!
Stevie
Stevie
Jah I did so for some time ago - but it wont hold as good - and it weights more too. I also used to heaten up the cable end and add some Tin, but thats too difficult.
Just screw off the glue-tube-cap and dip the cable end into the tube. Thats it.
It will hold the stings together forever.
Another tip- I use bar tape instead of rubber grips (as does my mate)... much lighter and a lot comfier!
Stevie
Stevie
Thats some serious weight saving, so much is for sure....
But i prefer the feel of a foam grip.
Another Tip is to use tape for the Chain stray. It can then be individually cut, where zou want to protect zour frame from damage.
And light is it too...
Or you could not bother protecting the chain stays and save the weight of the tape
Replace rim tape with strong sellotape (layers according to the pressure you run).
I like the cork grip idea.
Cheers
Cheers
How many of you use a saddle bag to carry spare tubes etc when not using a trailpack? Instead... you could use a couple of old toeclips to strap a wee bag of tools to your saddle rails and use some electrical tape to tape a spare tube to your seatpost... saves the weight of a saddle bag
Or an old drink bottle cut open, tools/tubes taped in with insulation tape. Keep it a cage to save more weight. (It's a common roadie idea around here)
But thats less space for a drink if you dont have a camelbak...
Does anyone actually use 2 bottles?
I've carried two, but I've used both.
I occasionally use two bottles on longer rides because i dont have a camelbak at the moment...
