How loose should rear cogs be?
I have a new ActionTec ti rear MTB cassette, and a pair of Soul Kozac disc hubs....when I slide the cassette in place over the aluminum shell, it seems without tightening the final ti threaded locking gear, I can rotate the cassette fore and aft quite a bit as the male rectanguler downward projections on each cog that fit into the slots on the cassette freewheel shell are narrower then the slots on the shell....
Are these supposed to be so sloppy?
- Ye Olde Balde One
DeepWalletDave wrote:I have a new ActionTec ti rear MTB cassette, and a pair of Soul Kozac disc hubs....when I slide the cassette in place over the aluminum shell, it seems without tightening the final ti threaded locking gear, I can rotate the cassette fore and aft quite a bit as the male rectanguler downward projections on each cog that fit into the slots on the cassette freewheel shell are narrower then the slots on the shell....
They shouldn't be loose at all, but with some hubs they often are. AC for example take this to the extreme, I presume to save as many grams as they can.
Ride lightly!
If the assembly is loose while fully tightened & all parts are new, then things are bound to get worse after some wear & tear...
Tip: Try to find an aluminum cassette spacer (maybe from an old XT-cogset?) and grind it evenly 'till it becomes ~2mm thick (tricky!). Slide it onto the freehub body, before the cassette, slide the cassette on the freehub body, then tighten (best to coat the freehub body with grease).
I had this issue about 6-7years ago, with a Hugi alloy freehub & a Shimano XT cassette... The above tip worked fine for me, hope it helps in your case!
Cheers,
Alex
Cheers,
Alex
I haven't tightened the locking gear yet, there is issues with that too as it is might need soem anti-sieze lube as it is way too tight and can't be screwed on much more then a thread or two by hand....it just seems they are awfully loose fore and aft in the interim....
Slightly OT:
How is the bike coming along Dave?
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
DeepWalletDave wrote:I haven't tightened the locking gear yet, there is issues with that too as it is might need soem anti-sieze lube as it is way too tight and can't be screwed on much more then a thread or two by hand....it just seems they are awfully loose fore and aft in the interim....
I would be inclined to try something like a shimano cassette to test the tolerances of the freehub body, and to see if the lockring will go in. Sounds to me that something is the wrong size
Good luck...
