9 speed cassette on a 8 speed rig?
Can I use a 9 speed cassette on my 8 speed set up?
My current cassette is warn and needs to be replaced. I'd like to slowly upgrade the parts to a 9 sp.
Can I adjust the derailer so it doesnt use the smallest gear?
Sorry about the stupid question, I don't want to waste $80-$100 on another XTR M950 if I can slap on a M960.
- Frankie - B
- Administrator
No, you can't
9 speed uses smaller cogs. The chain has to be smaller too. Better save a bit longer and get yourself the full setup!
- Frankie - B
- Administrator
no, not necesary
only rear mech, chain and rearshifter. Most modern rings are already smaller.
- Frankie - B
- Administrator
You can use 9 speed chainrings with 8 speed. But you can not use 8 speed chainrings with 9 speed.
- Frankie - B
- Administrator
that's chainrings, not cogs?
danielgillett wrote:You can use 9 speed chainrings with 8 speed. But you can not use 8 speed chainrings with 9 speed.
? sure you can. Buddy of mine uses an ancient TA-crank (when that was built it was still the time of friction-shifted 7spd) with Campagnolo 10-speed without any problems.
I run a Campa 10-speed setup with a 9-speed DA chain and a FSA Shimano 9-speed crank.
That whole compatibility is a little overrated, if you ask me. There are issues, but they concern shifters, rear derailleur and cogs.
There may be exceptions, but cranks are typically not a problem.
Martin
- Similar Topics
- Replies
- Views
- Last post
- 2 Replies
- 306 Views
Last post by vejnemojnen
Sun Jan 14, 2018 10:22 am
Help Identifying 11-40 11-speed Cassette
by Bhaalgorn » Wed Jun 07, 2017 9:01 pm » in Cyclocross / Gravel / Touring - 5 Replies
- 831 Views
Last post by Bhaalgorn
Thu Jun 08, 2017 12:16 am
- 12 Replies
- 1288 Views
Last post by efeballi
Sat Oct 07, 2017 10:10 pm
- 4 Replies
- 222 Views
Last post by ooo
Fri Apr 06, 2018 7:50 pm
- 42 Replies
- 4931 Views
Last post by fh8425
Mon Jan 01, 2018 4:54 am
