It is currently Wed Jan 17, 2018 4:01 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Mon Apr 05, 2004 7:59 pm
Just curious as to what pressures you run...
Please state:
pressure
tyre & tube
weight
wheelset
tubeless, etc.
I use 28-32psi on the front and rear.
I use Nokian boazobeana X tyres & nokian ultralight or continetal tubes.
I use the non-ust Crossmax wheelset (but next week, the new one!!)
I use no sealant of any kind.
 Post subject:
PostPosted: Mon Apr 05, 2004 8:27 pm
Administrator
pressure:.............35 psi
tyre & tube:..........Michelin Jett / Schwalbe FF / Kenda Kozmic lite
weight:.................608/672 365/368 376/375
wheelset:..............Mavic x221 rim; db spokes;Sram/GT hub Mavic crossride
tubeless:...............Nikh-tubes (Tubeless DIY)
Both combo's are very good! No problems at all. I used to run Air B tubes.
{USERNAME} wrote:
 Post subject:
PostPosted: Mon Apr 05, 2004 8:37 pm
pressure = 40psi
tyre & tube = conti vert pro 2.3 + specialized standard tube
weight = 168 pounds
wheelset = Phil wood, mavic 517
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
 Post subject:
PostPosted: Mon Apr 05, 2004 8:40 pm
Pressure: 35-40psi depending on the course
Tire/Tube: Conti Explorer Protec / Stans
Wheelset: Brontrager Race Lite UST with stock rimstrip removed and replaced with Stans.
Weight: 165-170lbs depending on how much I eat and train!
 Post subject:
PostPosted: Mon Apr 05, 2004 9:12 pm
Administrator
I weigh 75 kilo
 Post subject:
PostPosted: Fri Apr 09, 2004 5:56 am
I ride a ghetto tubeless setup......homemade rim strips made from 20" presta tubes from recumbents (see ma' recumbents HAVE brought something useful into the world!!!) cut in half longitudinaly, with Ghetto Juice....aka 1/2 water....1/2 liquid latex from hobby shop.
I run Huchinson Python airlights/ Huchinson Mosquito Airlights/ or WTB Nanoraptors .....with 22 psi front and 24 psi rear....except in training funrides, when I run 22 front 20 rear....I used to ride 20/18 but my rims were suffering dearly
if you give what you've always given, you'll get what you've always gotten
-some smart dude
 Post subject:
 Post subject:
PostPosted: Mon Apr 12, 2004 12:37 am
Taking into consideration ten psi up or down depending on course.
average Pressure - 40 frt 50 bk psi.
Tire/tube - Conti Twister Pro or Supersonic depending on the terrain in dry hard to semi-hard conditions. Specialized Enduro Pro's for very loose to muddy condition. I run Stan's
Weight - 140 lbs.
Wheelset - Brontrager Race Lites
There are no new unread posts for this topic. Tyre pressure opinions please.
JScycle
21
1908
Sat May 20, 2017 10:42 am
JScycle View the latest post
There are no new unread posts for this topic. gp4000s 28mm on 21mm internal widht rims + 70kg rider ==> tyre pressure?
in Everything wheels
Delorre
10
1162
Wed Mar 29, 2017 8:49 pm
Delorre View the latest post
There are no new unread posts for this topic. Seatpost creaking in frame (and ideal insertion)
Alexandrumarian
9
647
Sun Oct 08, 2017 7:07 pm
Alexandrumarian View the latest post
There are no new unread posts for this topic. Campagnolo Zonda/ Racing 3 (2018)C17 V Shamal/ Racing Zero C17
ClydesdaleChris
12
1290
Wed Dec 13, 2017 12:02 pm
sawyer View the latest post
There are no new unread posts for this topic. Training Tire and which pressure to use?
in Training
3Pio
Mon Oct 30, 2017 6:57 am
3Pio View the latest post
Users browsing this forum: No registered users and 7 guests
cron
