It is currently Thu Jan 18, 2018 9:21 am
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: Gokinetix Rotor???
PostPosted: Sat Mar 27, 2004 6:42 am
Found this special rotor at http://www.gokinetix.com
A rotor that
·Weights less than 60 grams – 50% less than Steel Disc.
·Withstands over 15,000 brake cycles on test rig.
·Does not warp – 4 times the heat dissipation of comparable steel products.
·Improved brake modulation, less fade and resulting in better overall brake feel.
·Excellent braking in wet and muddy conditions.
·Available in standard 140, 160 and 205 mm sizes.
·Excellent for DH & XC riding.
·Available with High Strength, Light Weight all Titanium Hardware.
·Compatible with all hydraulic and mechanical disc brake system.
DURA-LITE Replacement Brake Pads:
Avid Mech and Hydraulic.
·Shimano XT/Grimeca System 8/ SRAM.
·Magura Marta.
·Magura Clara and Louise.
·Shimano Deore Mech/Nexave Hyd.
·Shimano Deore Hydraulic.
·Shhimano XTR.
·Specialilty formalted friction materials to maximize pad life and
braking performance.
Benefits / Properties:
High strength to weight ratio (Higher than T-6 Aluminum)
• Extremely wear resistant (Superior to Steel)
• High rate of heat dissipation (4 times that of Cast Iron)
• 30% - 40% Stiffer than Aluminum
Brake pad formulation specifically developed to minimize pad and rotor wear, squealing, break in period while maximizing brake performance
Crashman like crashing, feel the rythem and ride.
 Post subject: re I need new rotors
PostPosted: Wed Apr 14, 2004 10:24 pm
I must replace 4 bolt rotors with std 6 bolt type to mate my new wheels.
The basic steel discs are going to cost me £60. :?
The Gokinetix look worthy of consideration :) .
Can anyone rate the Gokinetix rotors?. Are they as hard wearing as claimed - better than steel?
I've emailed the company for more info and will let you know if I get any useful feedback.
 Post subject:
PostPosted: Wed Apr 14, 2004 10:55 pm
Sounds interesting. I would like to hear what they have to say.
 Post subject:
PostPosted: Thu Apr 15, 2004 8:52 am
How do their stats compare with Stan's Al rotors?
 Post subject:
PostPosted: Fri Apr 23, 2004 8:06 pm
I've been to both websites and both claim no squels, more power, yada yada. I'm also interested in this. If anyone has or had any experience with Aluminum rotor, I'm interested to find out how they perform.
 Post subject:
PostPosted: Fri Apr 23, 2004 9:10 pm
Administrator
Nikh can tell you all about it!
{USERNAME} wrote:
 Post subject:
There are no new unread posts for this topic. Rotor Hubs
in Everything wheels
wpccrunner
Fri Aug 25, 2017 6:36 am
Garrison View the latest post
There are no new unread posts for this topic. Rotor hubs
Alexandrumarian
Fri Dec 01, 2017 10:33 pm
kavitator View the latest post
There are no new unread posts for this topic. Rotor 3D+ change shaft
Erwin
Sun Oct 29, 2017 2:50 pm
dfischer1 View the latest post
There are no new unread posts for this topic. Anyone for Rotor UNO at a gravel bike?
wheelsONfire
16
2093
Wed Jan 10, 2018 5:14 pm
reippuert View the latest post
There are no new unread posts for this topic. Attachment(s) 140 front disc rotor
[ Go to page: 1 2 3 4 ]
ooo
52
2937
Mon Nov 13, 2017 2:48 pm
uraz View the latest post
Users browsing this forum: No registered users and 3 guests
