Short mountain bike cranks
by morganb
Are there any options out there at 155mm or below other than SRAM NX? That's what I've been running and they function fine but are an absolute boat anchor and I'm pretty sure they only manufacture them intending to be on nice kids bikes. I've seen one or two older square taper models in that length but those won't work with a number of modern bikes.
by poynt
only light weight ones I have used are the LIghtnings but they only go down to 160mm.
by drider85
Again not really that light but Trail Craft come in 140 and 152. Canfield brothers comes down to 155.
Sent from my MotoG3 using Tapatalk
by TheKaiser
morganb wrote:
Mon Feb 19, 2018 5:56 pm
Don't have an "off the shelf" solution, but you might want to look into options from Rotor. They are going down under 155mm on their new road cranks, and the system is fully modular, with an interchangable spindle and spider. If they are similar to Cannondale and Race Face, then the same arms could be run on road or MTB (or fatbike for that matter) with a simple swap of the spindle and spider. I haven't looked into the spline pattern to see if you could fit compatible MTB parts onto these arms, and I'm sure it wouldn't be cheap, but if you are really committed then it is something to keep in mind: ... k-spindle/
Also, if you aren't afraid of some fabrication, I have seen people running cut down XTRs for this purpose.
