reducing 15mm thru axle fork to 12mm
spud
by spud
Is anyone aware of a kit that allows you to convert a 15mm fork to 12mm? I'd like to be able to switch wheels between two bikes, one has 15mm fork and the other has 12mm fork. I'm looking for sleeves which thread into the dropout on the screw side and slide in on the QR side to allow use of a 12mm thru axle, as opposed to running a 15mm OD tube thru the hub. Unfortunately, my front hub doesn't allow quick and easy conversion between 15 and 12 via end caps.
LeDuke
by LeDuke
Why not just use a sleeve to convert the hub, allowing it to switch between 15mm and 12mm?
https://www.ebay.com/itm/PDXTI-15mm-to- ... SwSZFZwdbs
spud
by spud
it's an alternative, but then I can't easily swap my wife's 12mm front wheel into my bike - it requires axle replacement, along with end caps.
ooo
by ooo
12mm fork compatible with 12mm and 15mm wheels/hubs (using sleeve from @LeDuke post)
15mm fork compatible only with 15mm wheels/hubs
UpFromOne
by UpFromOne
Yep, converting it to a 12mm fork can be done, but would pretty much have to be permanent.
spud
by spud
any suggestions on where to start? if I could find a reducing sleeve to thread into the threaded side, the QR side is easy.
joejack951
by joejack951
spud wrote:
Wed Dec 27, 2017 2:46 am
How much is it worth to you? It is easy enough to make but making only a handful of parts means it won't be cheap. This is something I have been considering making for my own bike utilizing a custom thru axle to fit the 15mm dropout but with a 12mm center section. And then the 15-12mm threaded adapter for the other side with some sort of hex feature to tighten and/or hold it in place while installing the axle.
UpFromOne
by UpFromOne
The threaded piece can be a simple shallow rivet nut. A smooth 15mmOD with M12 threads inside. If you have the right piece, you may not even need to glue it into the fork.
Same with the head side, just use a collared spacer, 15mm OD x 12mm ID.
Then a 12mm thru-bolt of proper length, with threads to fit the rivet nut pitch.
OR, you could send your fork to a carbon fab and have them permanently re-size the axle holes.
02GF74
by 02GF74
spud wrote:
Fri Dec 22, 2017 4:15 am
How often do you need to do that?
ooo
by ooo
If it is possible to change hub end caps from 12mm to 15mm on your wife's bike wheel - you only need to do that once, and get @LeDuke sleeve.
With new end caps you can use wheel on your bike as is; just insert sleeve before returning wheel to your wife's bike (no need to change caps again)
joejack951
by joejack951
I have the 15mm to 12mm thru axle designed. Just need to draw the thread adapter. I think it will be best to use 'timed' threads a la Timeserts to maintain as much integrity in the part as possible. So it will be M15x1.5mm outside and M12x1.5mm inside. And I think it would look super clean with a hex recess to tighten it in place but two holes on the flange for a spanner wrench would be simpler, lighter, and cheaper. Thoughts?
spud
by spud
joejack951 wrote:
Sat Dec 30, 2017 7:45 pm
That's the first thing I looked at, but no 15mm timesert exists that will reduce down to 12mm. 16mm reduces down to 12.
joejack951
by joejack951
spud wrote:
Sat Dec 30, 2017 10:42 pm
I would want something custom in aluminum anyway as Timeserts are all steel. I'll finish up the CAD and post some screenshots soon.
joejack951
by joejack951
Weight should be about 30 grams.
spud
by spud
that's a VERY NICE solution. Custom machining would be pricey though. My original hope was to use a stock timesert or something like it, and simply bond in a bushing to the DR side. Maybe someone will do a run of these parts, but I wouldn't hold my breath. I could just buy a new fork for $200.
