THM Clavicula M3 -- Crank arm to spider engagement?
drasnian
by drasnian
Hi all.
I'm mulling over a new crankset for XC. Looking at the Clavicula M3, I can't work out how the drive side crank arm secures to the spider to drive the rings. The spider has depressions in it, and it looks like the 4 crank arm 'fingers' may just sit in their seats in the spider. Surely that is not all (?) If it is all, then am I correct in thinking that the only thing holding the drive side crank against the spider is the tensile load on the spindle supplied by the bearing preload on the non-drive side crank arm?
Surely not. Please tell me there is some sensible mechanism by which the crank can provide torque to the spider.
Cheers,
Simon
Klaster1
by Klaster1
The image of a spider from THM website shows an interface very similar to Specialized and Lightning, I bet it's compatible.
UpFromOne
by UpFromOne
The M3 road and mtb versions are completely different. The splined mtb spider is secured with a lockring - it has nothing to do with bearing preload. But I don't know if the spider has the exact same pattern as Specialized/Lightning.
FWIW, I prefer the narrower Q factor of the road cranks on my XC bike, so I run a double chainring on M3 road cranks, with both being 5-bolt 58bcd, the same pattern as the road spider attachment. I use a standard granny for the inner, and a larger custom made 58bcd chainring as the outer. Both rings are secured into the arm with 14mm long titanium chainring bolts. 5mm spacers between the rings. Works very well, and a definite WW win.
drasnian
by drasnian
UpFromOne wrote:The splined mtb spider is secured with a lockring
Ah, so that circular metal piece on the base of the spindle (in the photos) is the lock ring? So it's just a case of take it off, chuck the spider on, then screw the lock ring back down against the spider (?)
UpFromOne wrote:FWIW, I prefer the narrower Q factor of the road cranks on my XC bike, so I run a double chainring on M3 road cranks, with both being 5-bolt 58bcd, the same pattern as the road spider attachment.
What's your XC bike? What Q-factor do the road cranks give you?
wheelsONfire
by wheelsONfire
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
UpFromOne
by UpFromOne
OP, yes, that is how it works.
M3 Road with a 22/36 on a climbing 29er hardtail:
