Light weight singlespeed crank set
AllenMtb
by AllenMtb
What is the lightest, reasonably priced singlespeed crankset I can get?
orange77
by orange77
Raceface Next SL
ryanw
by ryanw
orange77 wrote:Raceface Next SL
These are $hit*.
My mate has snapped two crank arms and the 3rd set had a load of play between the drive side crank to spindle.
*These were the SL G4's, so the normal SL's may be different?
'16 Cervelo S5 - 6900g
'17 Focus Mares Force 1
'15 Scott Addict Team - 6850g Sold
'17 Cervelo R3D DA - 7580g - Sold
'16 Cannondale CAAD12 DA Disc - 7560g - RIP
Gullholm
by Gullholm
Sram XX1 Eagle is 391g for 175mm GXP arms, about 20g heavier than RaceFace Next SL but can be found quite a bit cheaper.
orange77
by orange77
These are $hit*.
Never had a problem with mine (G3). Hope it stays that way...
LeDuke
by LeDuke
These are $hit*.
Sounds like your mate doesn't know how to assemble bicycle parts correctly.
ryanw
by ryanw
LeDuke wrote:
These are $hit*.
:roll: He's a national masters enduro champ...
Snapping two crank arms in half has nothing to do with installation :idea:
LeDuke
by LeDuke
ryanw wrote:
LeDuke wrote:
These are $hit*.
I was referring to the "load of play between the drive side crank to spindle". Pretty easy to fix that.
And, I know plenty of bike racers who know next to nothing about the workings of their bicycles. I can win a WC XCO race, but that doesn't mean I know how to maintain a bicycle.
weeracerweenie
by weeracerweenie
I run XX1 GXP cranks. Never actually weighed them but they perform exceptionally well, have stages compatibility and a mass of chain ring options to suit them from the aftermarket. Got them on a supplier special for 250nzd
I guess there's worse hobbies than making a bike light? Right?
11.4
by 11.4
Assuming you're using this on the road and in competition, you are typically facing hills and having to put a lot of out-of-the-saddle leverage on the cranks. Pure weight savings tend to cost you there. I've seen riders with stability problems because they went to ultralight cranksets. The Dura Ace 7710 track cranks are one of the lightest track cranks out there -- hollow crank arms and a 7700 road bottom bracket is very light (some of the lightweight cranks save weight but then give it away with the bottom brackets you have to use).
LeDuke
by LeDuke
11.4 wrote:Assuming you're using this on the road and in competition, you are typically facing hills and having to put a lot of out-of-the-saddle leverage on the cranks. Pure weight savings tend to cost you there. I've seen riders with stability problems because they went to ultralight cranksets. The Dura Ace 7710 track cranks are one of the lightest track cranks out there -- hollow crank arms and a 7700 road bottom bracket is very light (some of the lightweight cranks save weight but then give it away with the bottom brackets you have to use).
This is the MTB subforum.
Not sure why you're recommending track cranks for offroad use. They won't fit, won't provide usable gearing, and would have a weird chainline even if you could find a chainring small enough to fit them on any modern MTB frame.
KWalker
by KWalker
Next SL cranks are also pretty damn stiff. I know tons of people who run them with zero issues. They are one of the easiest cranks to setup. The only issue with them is actually the BB creak, but again any decent mechanic should be able to prevent that.
Gramz
Failed Custom Bike
11.4
by 11.4
Ooops. I just saw it as a recent thread and didn't notice it was MTB and not road.
EPICBYTES
by EPICBYTES
I have 170mm RaceFace Next SL , all in (BB and spacers included) is 504g
EDIT: Pretty damn easy to set up and cinch system is awesome
carpetrunner
by carpetrunner
Spesh s-works cranks - maybe the older model with a directmount ring is just a little lighter than the new one?
or Lightning http://www.lightningbikes.com/cranks/
- carpetrunner
Spesh s-works 2015 model
