It is currently Sat Aug 19, 2017 9:54 pm
 Post subject: soft compound tires
PostPosted: Thu Mar 04, 2004 2:57 pm
Is soft compound tires are heavy?Something is wrong with my bike :evil:
Crashman like crashing, feel the rythem and ride.
 Post subject: ...
PostPosted: Thu Mar 04, 2004 3:01 pm
weigh them.
.....but it still has to work!
 Post subject:
PostPosted: Thu Mar 04, 2004 3:12 pm
oops. :oops: find out my weight of my tires already. thanks
Btw, can i ask about disc brake pad? what should i do when my pad contimate with mineral oil? any solutions to get rid of it?
 Post subject:
PostPosted: Thu Mar 04, 2004 4:23 pm
Put them in the oven and bake them.
I used Mike one-speed's method and it worked:
"I baked my Formula pads after fluid contamination with excellent results. Simply place the pads pad-side-up on a cookie sheet, cook at 400F for ~20 minutes. Be sure to open the windows and crank-up the fan, because it will get smokey"
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
 Post subject:
PostPosted: Thu Mar 04, 2004 10:35 pm
I'm not sure if soft are heavier than hard compound though soft would loose their weight quicker.
What is wrong with your bike?
Thnax for the tip with the pads Nik.
Brian
 Post subject:
PostPosted: Fri Mar 05, 2004 12:40 am
soft is usually lighter as far as i know because it is more porous which makes it wear out faster (not as dense) ....a good example is a Conti Twister Pro and a Twister Supersonic .....same tire but the Supersonic gets it's lighter weight by a softer compound which is why it wears out faster than the Pro version ...keep in mind that not all of the weight savings is from the softer compound ...alot comes from probably thinner sidewalls.
 Post subject:
PostPosted: Fri Mar 05, 2004 1:22 am
Do people find the softer compound makes much difference in the dirt?
On the road it is noticeable, but I would have thought the tread patern was more important for off-road grip.
Brian
 Post subject:
PostPosted: Fri Mar 05, 2004 2:07 am
I have the Schwalbe Fast Fred Light 2.0 with the qualifier compound which is quite soft ...there isn't very much tread but I still like them and haven't had any problems with grip with them
They will wear out faster though ..definitely a race day tire only
 Post subject:
There are no new unread posts for this topic. FS: Lots of Oakley Gear- Soft Vault, Custom Painted Radarlock frames, and Radarlock lenses
boots2000
Mon Jun 12, 2017 10:52 pm
boots2000 View the latest post
There are no new unread posts for this topic. Suggestions on tires
addictR1
9
763
Sat Jun 10, 2017 11:42 am
wheelsONfire View the latest post
There are no new unread posts for this topic. Zondas can I use 23 mm tires??
in Everything wheels
Luv2ride60
Tue Feb 07, 2017 11:01 am
GambadiLegno View the latest post
There are no new unread posts for this topic. Skinny tires in the TdF
Asteroid
14
1596
Thu Jul 13, 2017 11:46 am
Stolichnaya View the latest post
There are no new unread posts for this topic. Best tires for wet, rough roads
nemeseri
38
2156
Tue Aug 08, 2017 7:06 pm
Bigger Gear View the latest post
Users browsing this forum: No registered users and 7 guests
