Saint/Zee pad material recommendations
MichaelB
by MichaelB
Hiya,
About to do some pad shopping. Note that I'm a roadie, so not worried about muddy/sandy performance, but do ride in the wet.
Been happy with my H01A Shimano pads for the Zee calipers, but after some feedback on the other options out there like the Uberbike (finned), Koolstop (finned) and Swissstop (Exotherm) pads out there, es0pecially the different compounds.
Any feedback ? I xcan get the Shimano H01A pads for A$22 delivered, so price is great.
Don't need metal/sintered pads, as I'm a roadie, but still do decent descents and speed with plenty of tight corners.
TIA
Michael
TheRookie
by TheRookie
You only need finned if you have been getting brake fade due to heat build up, if you haven't they are a waste of time/money and weight.
I'd stick to the Uberbike racematrix without fins if I were you, should be about A$13 based on the UK price, no need to pay more.
MichaelB
by MichaelB
Agree with the part about finned - they diod come in handy on a Italy/France trip last year.
Descending down decent hills like La Plagne, Umbrail Pass, Passo Fedaia (steep side), Passo Pordoi, Monticello, Cormet de Roseland etc they earned their keep (i'm more of a clydesdale).
What is the like like on the Uberbike Race Matrix pads ?
TIA
TheRookie
by TheRookie
Unfortunatley with fins you don't know if you need them until it's too late, or whether they were any use until you try without! Dragging brakes is the usual cause of fade, repeated heavy use isnt usually an issue as long as you get off the brakes in between.
Not sure what that question was meant to ask?
RedCoke
by RedCoke
Cuz you said you are rodie, you don't need metal pads. In my opinion, all other resin pads are not very different, but I recommend genuine.
prodigy
by prodigy
Resin pads and riding in the wet don't really go together, unless you want to change pads on a weekly basis.
I'd recommend Uberbike Race Matrix, they last as long as original Shimano sintered pads, have initial bite similar to resin pads and hold in the wet like no other.
I've tried almost all what's out there (except Swisstop), but Uberbike for the price can't be beaten.
TheRookie
by TheRookie
Resin pads work fine in the wet on road (without the crud it brings with it on an MTB).
On my commuter I've replaced just one set of front resin pads in 6,500 miles, rears are original. Used right through the 'dry' UK winter!
MichaelB
by MichaelB
prodigy wrote:Resin pads and riding in the wet don't really go together, unless you want to change pads on a weekly basis.
Thanks for the feedback. Have some Race matrix on their way
Thanks for the replies :thumbup:
