It is currently Sun Oct 22, 2017 10:58 am
Post new topic  Reply to topic  [ 55 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Alpha ceramic rotors
PostPosted: Fri Dec 16, 2016 12:25 pm
This is apparently one of their discs
and this one
PostPosted: Fri Dec 16, 2016 2:17 pm
Test completed. I don't recommend Carbon rotors (all Carbon rotors in general, including these ones).
Not a catastrophic failure but I understand now why rotors are made of metal. That's because metal can be bent. As I mentioned, the rotors are perfectly flat, on the table. But once mounted on the hub they are out of true. I used my torque wrench to tighten the bolts evenly at 6 Nm (recommendation from Alpha). Could be that the rotor contact points of my hub are not perfectly flat or that when you compress the rotor the constraint causes warp. Don't know. The only thing I know is that because it is made of Carbon you can bend it. You just can't fix it. Period.
They don't rub badly, but they do. I could certainly massage them to stop rubbing (by a perfect alignment of the caliper and some magic spells) but this is not a robust solution.
Then, they seem to stop me efficiently (tried on the front brake only). I guess there is some breaking-in that needs to happen, but they are a bit noisy (dry weather) and vibrate. Hopefully this is just because they are new.
So, again, I don't recommend Carbon rotors. Never, ever would I use these on a MTB. You hit a rock and they most likely break, leaving you w/o brake. I'll try to fit them on my road bike once I have my carbon wheels built, but if I had the option to send them back I would.
PostPosted: Fri Dec 16, 2016 2:20 pm
That is the exact issue I had with all iterations of the Kettle carbon rotors, well that , and a screeching noise that would wake the dead under heacvy braking.
PostPosted: Fri Dec 16, 2016 2:27 pm
From the photo's they look like plain CF sheet cut to a disc, is that they case or are they actually 'special' in come way?
I have a CF bash made out of a sheet of 2.5mm, cost me £20!
PostPosted: Fri Dec 16, 2016 4:29 pm
Honestly it would well be Carbon in Epoxy!! I found the source of the pictures above. They are indeed Alpha rotors.
Test is over for me, and I've already requested my money back :-[
For those who don't speak Spanish they can use Google translate.
http://www.foromtb.com/threads/discos-d ... s.1366597/
Not taking any risk. Lucky I paid with my American Express card, if they don't send the money on their own I'm protected 90 days past the purchasing day.
PostPosted: Sat Dec 17, 2016 2:47 am
My friend ordered a set and his first ride on them went well, however, on his 2nd ride they ended up looking exactly like the pictures above. They are trying to blame his choice of pads (Swiss Stop Exotherm) but it doesn't seem like it is an isolated incident. I would definitely avoid these until they refine the process or perhaps make their own pads.
PostPosted: Sat Dec 17, 2016 7:57 am
I do t think it's a case of refining the process, that would imply they had a process to begin with!
PostPosted: Sat Dec 17, 2016 11:50 am
thanks for the pictures, saved me a lot of trouble with mine :)
Ellsworth Truth = 9371g
PostPosted: Sat Dec 17, 2016 11:59 am
If Alpha bothered to have done more R&D before releasing these to public use, ie: they cold recommend a specific pad that they know works then maybe we'd all be a lot happier and feel more covered if there was a failure and were using recommended pads etc.
PostPosted: Sat Dec 17, 2016 12:53 pm
How can they blame pad choice if they don't say which pads to use, or not use? :noidea:
PostPosted: Sun Dec 18, 2016 6:38 pm
The directions were long and made no sense. When he emailed them about the failure they told him that they only recommend organic pads and that was the reason his set had failed. Since his first order was lost in the mail, Alpha sent him another set, which conveniently showed up after the current rotors disintegrated. I'm not sure if he is willing to test them again or not, but if he does it might just be at one end of the bike.
PostPosted: Sun Dec 18, 2016 10:16 pm
Thanks for placing the bet, SportingGoods. I hope you get your refund.
FWIW, a cursory search finds several successful carbon rotors on motorized applications:
http://braketech.com/axiscmc-rotors/
http://www.wilwood.com/Rotors/RotorList ... C%20Rotors
http://www.starfiresystems.com/docs/mat ... 4-2010.pdf
Years ago I had the BrakeTech CMCs (pic attached) on my Honda superbike, and they were the best brakes I ever used.
Why in the hell can't someone just use a smaller version of these materials for bicycles?
PostPosted: Sun Dec 18, 2016 11:19 pm
Maybe if they were made of some sort of carbon/ceramic by a company like brembo I'd try them out, looks like these are just 3k weave with maybe a different resin? I sincerely hope no one was hurt experimenting with these!
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
PostPosted: Sun Dec 18, 2016 11:33 pm
The only one that has a price listed is the Willwood, and it's $2400 per rotor...
How mch did they cost on your Honda, and who's going to pay that for the much, much smaller weight saving on an MTB?
PostPosted: Mon Dec 19, 2016 5:24 pm
wingguy, yes they were expensive but worth it.
I'm suggesting that the proper materials have already been worked out, it's just a matter of not trying to short-cut the proven designs.
As for our required sizes and thicknesses, it appears that Alpha (a "motorcycle" company no less!) did in fact short-cut the materials and designs. Hopefully one day some company will do it right and take over the racing market. For now still a dream.
There are no new unread posts for this topic. Upgrade from wheels with Gipiemme H32 to WR Compositi T33-W ALPHA
in Everything wheels
3Pio
Tue Apr 18, 2017 10:38 am
3Pio View the latest post
There are no new unread posts for this topic. Build recommendations for Powertap GS (and Stan's Alpha 400)
icenutter
26
2324
Mon Dec 19, 2016 4:49 pm
LouisN View the latest post
There are no new unread posts for this topic. Light weight rotors
in MTB
AllenMtb
13
1887
Thu Mar 30, 2017 4:05 pm
gtinut View the latest post
There are no new unread posts for this topic. Attachment(s) Magura MT8 brakeset w/ rotors NEW,Cannondale HM fork
bikemaniack
Mon Sep 18, 2017 11:55 am
bikemaniack View the latest post
There are no new unread posts for this topic. Why disc rotors are so freakin close to frame ?
stormur
Sun Feb 12, 2017 7:39 pm
mattr View the latest post
Users browsing this forum: Kastrup and 9 guests
