Brake rotors? Which one?
I am building up a lighter XC wheelset and looking for 6-bolt 160mm rotors.
Apparent I haven't been reading much about them. I saw some that looks like 2-piece rotors, some with Ti bolts, and then there are the different design of the rotor itself.
Which ones are recommended? Doesn't need to the lightest, but leaning slightly towards reliable as well.
If you want light then Ashima windcutters or Ai2's are the place to go, also KCNC do some v light Ti rotors if you have a spare £120 to burn (each)
Personally I've been running SRAM centrelines for the last 18months, they're not the lightest but have been quiet and stop well.
Oh and Ti bolts are definitely the way to go
Hope X2 Race for light rotors that actually work. Con is the price.
KCNC are the best of the light, cheap rotors but warp horribly with extended braking and are pretty much a write off in the wet.
I am now on the cheapest Shimano jobbies purely for a cheap fit and forget option. Seems many people go the same way- either SRAM or Shimano @ 100g+
Ashima ai2 are cheap, but cutout designs seem to wear through pads faster. They won't stop quite as powerfully as your stock XT rotors, but in most situations they're close enough and you will get used to it.
stockae92 wrote:I am running Shimano XT brakes, should I stick to Shimano rotor or it doesn't matter?
Doesnt matter.
I run a cheap and cheerful alligator lightweight disc on the back of mine, has been on for 4-5 years now, works just fine.
On the front I use an A2Z with alloy spider, about 20g heavier but a full braking surface, that's been on about 2 years now.
I'm running XX WC with Ai2 rotors. Works great,and brake power is very good. On my opinion,it's very important witch brakes you are using. Avids has more power than Shimano brakes,but that's a bit OT
