11 speed shimano road on XT wheelset?
Hi there,
Just wondering if it is possible to fit an 11 speed 105 road cassette on a Deore XT 8000 wheelset?
I assume the splines are identical?
Cheers
Cheers
2015 FELT AR1 TeXreme! http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134989
- ultimobici
- in the industry
- Contact:
In short no. Shimano Mtb cassette bodies are the same as 8/9/10 road hubs, so 11 speed road cassettes are too long to fit.
Cool, thanks for the reply.
In long.. the reason a MTB 11 speed cassette can fit on the 10speed freehub body is because the larger 40T+ sprockets overhang the spokes and give clearance. A smaller geared road cassette with 28T, 30T or even 32T need the extra width (2.85mm) of the 11speed road specific freehub body.
or filed the back side of cassette body.Than it will work.
- ultimobici
- in the industry
- Contact:
And watch as your rear mech destroys itself and the rear wheel.....
- Moderator
ultimobici wrote:And watch as your rear mech destroys itself and the rear wheel.....
Not true, done it plenty of times. You just have to ensure you have the space to do so on the wheelset you intend on using.
Using Tapatalk
- ultimobici
- in the industry
- Contact:
Nefarious86 wrote:ultimobici wrote:And watch as your rear mech destroys itself and the rear wheel.....
Doesn't look like there is enough material to allow it on this wheelset, does it?
- Moderator
Machine it out of the casette then more than one way to do it.
Using Tapatalk
- ultimobici
- in the industry
- Contact:
Nefarious86 wrote:Machine it out of the casette then more than one way to do it.
Problem is, while you may be able to fit the cassette on to the wheel, the largest sprockets are not large enough to allow sufficient clearance for the rear mech. MTB systems are designed to have the largest sprocket (40/42/46T) overhang the same vertical plane as the edge of the hub body. If you are using a 105 cassette the 32 is highly unlikely to be large enough to place the mech low enough to clear safely.
I can see the point of using this hack to make an existing pair of old wheels usable with 11 speed. It is another thing entirely to do it to use a new product when there are better options around. This is a wheelset that is optimised for MTB use. It has a pressure restricted rim as well as not being road 11 compatible. In short a waste of time doing anything to.
- ultimobici
- in the industry
- Contact:
Yep
A good friend rode 11 speed Ultegra cassettes on his XTR wheels that have an 8/9/10 freehub body. He had the material machined off the back of the cassette. He raced cyclocross on this setup at a very high level. Yes the derailleur gets closer to the spokes than intended. But if you keep it tuned you're fine. It was an 11-28 cassette.
