Pace RC31 leg diam
nicrump
by nicrump
Does anyone know the O.D. of the legs on the Pace RC31? Has anyone used the bolt on canti studs for that? I am curious if there is any problems with slippage under hard braking.
http://www.wiggle.co.uk/v2_product_deta ... 5360006578
Tippster
by Tippster
I run disk brakes on my Pace RC-31s
Cant comment on V-brakes
Although, there appears to be a sticker covering a small 1mm hole aboput where you would put the v-brake canti studs. Could this be to stop slippage.
Pace have a reputation for well engineering components. I wouldn't think they would slip. I will measure the diameter today and post the findings.
Jerry Serra
by Jerry Serra
I ran the V set-up. No issues at all. Put about 4000 miles on that fork last year.
-Jerry
nicrump
by nicrump
Tippster, did you get a chance to measure those fork legs?
nikh
by nikh
What have you got up your sleeve Nicrump?
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
Tippster
by Tippster
Measured at the yellow band (where the v-brake bosses are fixed).
112mm diameter.
nicrump
by nicrump
nikh, I think you know. I have given up on carbon disk in lieu of a sub 6lb rigid fork. I want to match the pace leg so I can use their canti studs. How does that sound? If one runs disk, it would be full carbon. No metal whatsoever. Can you confirm your pace leg diam?
nicrump
by nicrump
112 mm? Diam? thats over 4"
520 Dan
by 520 Dan
112 mm is probably circumference ( I think i spelled that wrong)
nikh
by nikh
nicrump wrote:I have given up on carbon disk in lieu of a sub 6lb rigid fork.
Isn't that a little on the heavy side :?:
I sold mine :(
I think 4" circum is about right from memory.
nicrump
by nicrump
DOH! i mean sub 600gm. why did you sell? what now?
nikh
by nikh
nicrump wrote:DOH! i mean sub 600gm. why did you sell? what now?
I now have a nice steel rigid fork from Surly.
It's a little bit heavier than 600g though!
nicrump
by nicrump
why did you get rid of the pace? did you not like the ride?
nikh
by nikh
The ride was harsh compared to the Surly it was beating me up tbh.
For me it was a race only fork, if I raced!
More of an explanation on this thread
Tippster
by Tippster
Sorry 112mm Circumference. (my smelling is por two!)
