How often do you need to bleed the hydraulic disc brakes?
I do it yearly, once the bike comes out of winter storage. Gets a complete once over. Pretty much strip down, clean and rebuild with new parts (where needed) and new grease/lubricant/copperslip.
During the year (if they were filled properly when last done) they are effectively a sealed system, new pads might be needed, but nothing else.
Training/winter bikes i generally just leave them until they either break or i have an issue. So maybe every 2 or 3 years.
They still never need bleeding. Just new fluid.
What brakes do you have anyway?
My old M765's weren't touched for about 4 years, other than 3 sets of pads.
No real need to change the fluid in a sealed system either.
So if you want to bleed (flush the fluid, no mileage in just checking it's 'full') that's fine, but you shouldn't NEED to.
In my opinion,brake fluid shp=ould be changed in normal riding twice a year<not only bleed,but totally changed. I heard,that very good riders(not only pros),changing fuid twice a month.
I have xtr's and flush the fluid every month. It gets dirty. Do I notice a difference? Not really. But the first bit of fluid that comes out of the caliper is always quite murky. fwiw, I ride my mtb about 30-40 hours per month in mostly dusty conditions with a couple muddy rides per month. Part of the reason all my bikes have shimano brakes; quick and easy to bleed with the funnel and a drain hose at the caliper.
I consider it preventative maintenance. Same with servicing lowers on my fork every 2-3 weeks. There, I do notice a difference however. Nothing like fresh slick honey!
good to know. i myself thought that a sealed hydraulic is good for several years...but i suppose it depends on the riding conditions and moisture in the air.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Most the muck that appears in the fluid is just contamination that is already inside the system and makes no actual difference
Source/proof?
Working as a mechanic for over 10 years it has always been told to me through various trainings and discussions that it is due to dirt/brake dust (and moisture too) seeping in through the moving pistons in the caliper. Yes, sometimes fluid comes gunky from the factory, which is why every bike I build get a flush before riding.
No more proof than any other hypothesis.
If water/gunk/muck is getting in past the calliper seals, why is the brake fluid (under significant pressure when braking) come out........a lot more......makes no sense to me.
I hope you're kidding - but considering the number of mechanicals I see at races, I'm not surprised. By then it could be too late if you are in the middle of a long race/ride. It's called preventative maintenance for a reason. Not 'wait until something goes wrong' maintenance.
