Who's using sealants in their tires [stans etc]
What type of sealant do you use and why?
1. Eclipse
15%
2. Stans
7
35%
3. Home made
7
35%
4. UST Standard [non ust tires with sealant]
5%
5. UST standard [ust tires]
5%
6. UST standard [ust tires with sealant]
No votes
7. Nagesti [non ust tires]
5%
8. Nagesti [nagesti or ust tires]
No votes
9. Nagesti [nagesti or ust tires with sealant]
No votes
Total votes: 20
Frankie - B
Administrator
by Frankie - B
Please answer the poll and state why :)
Xterra Racer
by Xterra Racer
Using Stans rimstrip and sealant.
Set-Up - Bontrager Race Lite MTB UST wheels with the plastic rim strip removed and the Stan's Rim strip in place. Use Conti Explorer Pro-tec tires.
Love the lower pressure allowance without the worries of pinch flats. Aslo lots of goat-head thorns were I ride and don't have to worry about those either. I do ride in some rocky areas so I'm running the Conti tires with the pro-tec side walls. Basically 15 grams more than the regular tires but I get the side wall protection from sharp rocks.
eurorider
by eurorider
trying to use home-made because i am poor :lol:
nikh
by nikh
You should have added one for good old tubes :wink:
I gave up with them because of the mess and I enjoy using Yes Tubes :lol:
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
Ye Olde Balde One
by Ye Olde Balde One
nikh wrote:You should have added one for good old tubes :wink:
lmao! I looked at the yestubes site, that's a riot! :lol:
Ride lightly!
Stylomilo
by Stylomilo
how do you guys make home-made tubes? :?
Crashman like crashing, feel the rythem and ride.
nzkiwiguy
by nzkiwiguy
stans because it was the first one I was introduced to. Run all wheels as tubeless(regular tires not UST0 except for my single spped, which i could not get the 2.35's to seal. So I got tubes with screw out valves and but the stans in the tubes.
I also put some stans in my tubes on my training road wheels. Have not had a puncture yet and i go dirt road a lot (conti all season tires)
Knut
by Knut
I use UST without sealant because I like the increased grip and lowered rolling resistance of tubeless. On the other hand I regularly switch between 3 pairs of tires (Conti Explorer UST, Conti Twister YesTubes and Conti GrandPrix YesTubes) and therefore don't use sealant...
Tippster
by Tippster
I must say that I have not used tubeless systems.
I'm put off by the fact that I change my tyres once a week and therefore use 1.5/1.75 Maxxiss Flyweight tubes (81g each).
The weight gain appears very minimal, although I have heard the arguements along the lines of rolling resistence and pucture proofing etc.
Depending on weather and terrain, I run 35 to 40 psi and suffer very few punctures. Rolling resistence, I cant comment on as I havent run tubeless.
Frankie - B
Administrator
by Frankie - B
Stylomilo wrote:how do you guys make home-made tubes? :?
Look at:link if you mean tubeless, and not tubes.
@ nikh, Yes tubes is funny! they completely overrule the use of tubeless :lol:
I have had good experiences with changeing tires. Only one negative, the complete tire exploding. Which decorated me green! :lol:
Joel
by Joel
Which sealants is the best for using in ROAD tubulars and how much weight does it ad?
Frankie - B
Administrator
by Frankie - B
I think it doesnt matter. Are road rims drilled? if not try eclipse or homemade! Oh, wait, tubulars. Then i think it should be eclipse. Very good available in europe too.
Why don't you activate the sealants topic in the road forum. This is interresting!
Joel
by Joel
Good idea, Frankie, I will do it.
JK
by JK
I am using crossmax SL wheels, regular tires with Eclipse valves and home made latex solution. Works great! Lots of grip, low weight, very low rolling resistance. German mag "Bike" tested Eclipse - the difference in rolling resistance between the same tire with tube or with latex was about the same as the difference between a semi-slick and a full knob tire!
I have sealed these tires succesfully: Maxxis Flyweight 330 (seals instantly...), Schwalbe FastFred 2.0, Fast Fred 2.35, Little Albert,Skinny Jimmy, even my old Ritchey Z-max WCS 1.9 sealed perfectly.
Note: I live in the Netherlands... I race on mostly hardpack to sandy or muddy trails, without any rocks whatsoever. If you live in a rocky neighbourhood, you better not use very light Non-UST tires.
Frankie - B
Administrator
by Frankie - B
Two days ago I managed to seal a Kenda kozmic lite with the nikh-tubes system on a crossride rim! The best thing was.... I only used a floorpump! 8)
I managed to do it by inserting the mixture and then roll the wheel around. After that pumping it up.
