Scott 910 hardtail
boots2000
by boots2000
Anyone riding a 2016 Scott 910 carbon hardtail?
I am thinking of getting one and looking for ride and sizing feedback.
Sizing seems to run small. I am 179cm tall and I think I could ride a medium or a large.
Pieter
by Pieter
I'm kinda in the same boat at 176. (not for the scale particularly, but seat tube and top tube are about the same length)
My seat is at 77.5 cm which means that the seatpost sticks a bit far out on a medium. (which I don't think looks good, looks like seatpost is almost as long as seattube)
On a large seatpost exposure seems normal. With a 80/90 cm stem on a L I'm not too stretched out.
I'm coming from a classic 26inch xc geometry though so position is quite different.
wingguy
by wingguy
Rides like a rocket, light, stiff, great acceleration, brilliant climber's bike though not as forgiving or with as good rear wheel traction over chatter as something like an F-Si or a BMC soft-tail.
You're pretty much bang in the middle of the sizes and there's a bigger difference in reach than stack so it's probably come down to how long a stem you want to run - unless you just want to get as low as possible on the front.
DanW
by DanW
I am 175cm with 74cm BB to saddle top distance and ride a Large with a 90mm -17 stem. Take that for what you will!
I would have thought Large would be better.
If you have a bike you are already comfortable on, use the stack/ reach to work out what stem/ spacer combinations you would need to fit on either frame size of the new bike and go from there
boots2000
by boots2000
Dan, Can you post a picture of your bike?
DanW wrote:I am 175cm with 74cm BB to saddle top distance and ride a Large with a 90mm -17 stem. Take that for what you will!
DanW
by DanW
It is stuck on the Turbo at the moment but I'll endeavor to get a pic up when it is freed from its shackles again :)
