Hi all,
has anyone ever come across a listing for specialized frames? I am considering to build up an S-Works mountainbike but have not come across any listings for the Stumpjumper FSR. All I know is that this years frame is 200g heavier than the 2015 one due to the SWAT door.
Best,
Greg
Specialized S-Works frame weights
I can if you add in the extra material to make up the strength lost through making a hole in what is otherwise just about the most efficient load bearing shape you can get (a tube).
I have a related question. How come some S-Works Stumpjumpers have an aluminum rear end and some have carbon? Does it have to do with different model years?
