27.2 mm dropper post?
rschenkels
by rschenkels
pictures with the xcp post available ?
the_marsbar
by the_marsbar
Here's a photo (sorry about the delay):
kenz76
by kenz76
you can also call Matthias Fluckiger if he can make you one.
27.2 and 250g. perfect! :thumbup:
gfeldy
by gfeldy
Mars did you order the 50MM? I was going to suggest it. In terms of weight you're probably better off getting the 50MM bc it weighs the same as the 35MM. I'm thinking about putting one on my Epic for the off season.
the_marsbar wrote:Here's a photo (sorry about the delay):
~GFeldy~
S Works Tarmac w/ EPS
S Works Epic HT Blurple tuned
Kitsbow
S Works Epic Blurple tuned - Sold :doh:
FS-i - Sold
Scalpel custom - Sold
EVO - Sold
the_marsbar
by the_marsbar
Yeah, I got the 50 mm version. It's really great. I can't imagine taking it off anytime soon.
KWalker
by KWalker
FYI Speci doesn't weigh the XCP with cable, housing, and remote as KS does. The Speci with that weighs 533 to KS' 535. KS is cheaper and 2x the travel. I have the 50mm XCP and it's great, but if twice the travel and zero weight penalty might as well use the KS.
Gramz
Failed Custom Bike
by Nefarious86
Except KS are hit and miss haha
Using Tapatalk
bikewithnoname
by bikewithnoname
Nefarious86 wrote:Except KS are hit and miss haha
To be fair I've not heard of any dropper post that has proven to be 100% reliable, I've had a reverb that kept sticking, a KS that won't drop and a Fox that did whatever it liked at random. I'm sorely tempted to bin the current KS I have and just run a normal post, about 75% of the time that's all I really need if I'm honest
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
the_marsbar
by the_marsbar
My Specialized XCP 50 mm has been just fine so far.
KWalker
by KWalker
Haven't heard many complaints about the 272 Integra so not too worried. The XCP is great, but if they're the same weight why not have more drop?
Gramz
Failed Custom Bike
the_marsbar
by the_marsbar
No local shops sell KS droppers here as far as I now. That was my main reason for getting the XCP. I also like the shape of the XCP.
KWalker
by KWalker
XCP is not a bad post. I still think about cancelling the KS. The one thing I like slightly better is the cable setup on the KS being very, very, very marginally easier to connect to the post head, but apparently the housing length is a bit finnicky. The XCP is great and I question the need for more than 50mm of drop on an XC bike, but I guess there is always the ability to try longer and go back to it if need be. The SRL lever is really well designed though.
Anyone ever use I-links or powercordz with an internally routed dropper? Seems like the ideal application for both.
Gramz
Failed Custom Bike
DanW
by DanW
The cable for the carbon KS posts is pretty much a Powercordz which is great in theory but awful in practice given how the cables are clamped in place and how fragile the Powercordz are. Since the cables are short the weight advantage is minimal so I stuck with a KCNC teflon coated jobbie after snapping the original inner. The outer for the carbon KS is a good place to lose weight on any cable operated post. Same as Tune Plastic Stuff or the cheaper alternative produced by Quaxar ("Ultralight") :thumbup:
