It is currently Tue Jan 23, 2018 1:22 am
Post new topic  Reply to topic  [ 37 posts ]  Go to page 1 2 3 Next
PostPosted: Sat Jan 23, 2016 12:23 am
I've just got my new XTR rear derailleur in the mail, and I've noticed that some of the bolts seems to be mad out of steel. Does anyone know if this is correct or not? Not that it really matters (reliability or weight wise), but this is the weight weenie forum, so I just thought I'd ask, to see if anyone could confirm/disconfirm this.
I edited the title, because I want to know about all possible weight saving options on the derailleur;)
6.07 kg MTB, Xiamen Carbon Speed CS-196-SL
Last edited by HaakonJohansen on Mon Jan 25, 2016 10:47 am, edited 1 time in total.
PostPosted: Sat Jan 23, 2016 5:23 am
I noticed the limit screws on RD-M9000 are now allen hex type and steel I think.
  • Shimano XTR RD-M9000 rear derailleur 11-speed short [RD-M9000-GS]
  • 165.9 EUR
  • IN STOCK
  • Price includes 19% V.A.T. which will be deducted when goods are leaving the EU. Shipping costs may be added.
PostPosted: Sun Jan 24, 2016 4:24 pm
Thanks for the answer. If upgrading the pulley bolts, can i get away using alu bolts, or should i get Ti?
PostPosted: Sun Jan 24, 2016 7:48 pm
Alu is fine, though I prefer titanium.
PostPosted: Mon Jan 25, 2016 10:50 am
Do you guys know the weight of the standard pulley wheels? Haven't got my torque wrench with me right now, and don't want to start taking things apart before I've checked the torque settings.
PostPosted: Mon Jan 25, 2016 2:31 pm
Dude stop worrying about every small detail :D
Shimano stuff is robust and the torque needed to tighten the jockey bolts is so little (2.5-5 Nm so make them just tight and don't crank on the allen key) just flippin' get on with it!
Just pull it apart and browse somehwere like R2 bike for comparison weights. There should be ~30g in the jockey wheels (Aerozine on ebay are super light, cheap and last well), alu bolts all over (eg Toronto Cycles) and Fibre Lyte outer cage.
PostPosted: Tue Jan 26, 2016 10:10 pm
I'm going to use the derailleur with a X0-cassette btw. Will I get much better shifting and/or reliability if I use a Goatlink11 or a RAD cage?
PostPosted: Wed Jan 27, 2016 4:48 pm
Anyone knows if this will improve gearing radically? Or am I better off saving some bucks, keeping the standard setup?
PostPosted: Wed Jan 27, 2016 8:36 pm
I've never come across anyone using either, nor ever describe the need for such a product therefore I wouldn't bother ;)
PostPosted: Wed Jan 27, 2016 11:37 pm
The one up rad cage was first designed to work with the larger "extender" 40, or 42T cassette cogs that fit behind conventional cassettes, so that people using 10 speed, could get closer to the gear range of sram 10-42T cassette. the stock shimano derailleur arm only worked well up to 36T. for its intended purpose yes the rad cage works very well. I live & ride somewhere very rocky where the standard carbon fibre xtr derailleur arm gets damaged within a few rides, where as the thicker, admittadly heavier aluminium cage of the one up rad cage, is still going strong.
If you're tuning the m9000 xtr that implies you're using 11speed. the cage of the m9000 will work perfectly with the stock xtr 11-40, by happy coincidence it also works with the sram 10-42. a few friends of mine are mixing m9000 xtr with a sram cassette with no issues. so for shifting performance alone, you wouldnt need the one up rad cage.
ta
scant
PostPosted: Sun Jan 31, 2016 9:23 pm
Found a site with a lot of tempting tuning bolts: http://www.fantic26.de/Bike-Tuning-Color-Concept-Parts-superlight-carbon-Bike-Components-MTB. There might be quite a lot of them that don't fit the M9000 though.
PostPosted: Thu Mar 24, 2016 10:19 pm
Sanded down the clutch lever for a much cleaner look;)
PostPosted: Thu Aug 18, 2016 11:41 am
Just came across a company that actually makes a Ti clutch bolts for the XTR M9000 derailleur! I've been looking real hard for this, and just yesterday I found the clutch bolt for the last generation XTR on their site. I immediately emailed them, asking if they could please make this for the M9000 as well, and it actually popped up on their site today! What are the chances?!
Underneath is the link to the bolt. I've ordered one already, of course;)
Titanium Planet
I've recently also asked Toronto Cycles (among others), about making this part in aluminum (with a steel insert where the bearing is mounted), and they seemed interested, but they told me they're quite busy at the moment. Hopefully it'll happen eventually though.
PostPosted: Fri Aug 19, 2016 5:06 am
Do you guys know the weight of the standard pulley wheels? .
Not M9000 but older XTR, just swapped my Jockeys for MT Zoom, original 17.5g, new 5.5g.
  • 165.9 EUR
  • IN STOCK
PostPosted: Sat Aug 20, 2016 7:13 pm
Was that 17.5 per pulley wheel?! That's a lot! I think it's right around 18 grams for the pair on the XTR M9000. I've got these ones with full ceramic bearings. Wight is listed with the steel ones. With the ceramic ones they're around 5.2-5.3 grams each.
There are no new unread posts for this topic. SRAM Red Front Derailleur Tuning (YAW)
prendrefeu
Wed Jan 10, 2018 12:45 pm
Jenmoss View the latest post
There are no new unread posts for this topic. nvroadie's Red Derailleur- Need all your crazy tuning ideas!
nvroadie
Thu Mar 16, 2017 9:53 am
Marin View the latest post
There are no new unread posts for this topic. Clutched rear derailleur 2x
jfranci3
15
1188
Fri Aug 11, 2017 2:56 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. XT di2 rear derailleur Cassette Options
velobob
14
1524
Tue Aug 08, 2017 8:33 am
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
Users browsing this forum: No registered users and 8 guests
