Clutch Dérailleur a must for 1x10?
Jmdesignz2
by Jmdesignz2
Turning my new project bike Titus Racer X into a 1x10
Currently Shimano XT Shimano shifter and rear der
Anyone have input on running 1x10 on horst link Racer X?
Do I really need a clutch rear or chain guide front?
Jmdesignz2
by Jmdesignz2
Oh yes wolf tooth 32t x sram xx 11-36t rear
26er
devinci
by devinci
For me a clutch is a must, riding without it has the chain drop quite a bit.
I saw you were looking for one. I have an xtr clutch der, it is used and could use a little tweak, clean and regrease though. I also have an almost new sram xo1 rear der and shifter, ridden 1 week. If you're interested pm me
jekyll man
by jekyll man
Not compulsory.
I'm just running standard xt rear mech with 11-36 cassette and Hope retainer 34?? chainring on a Trance 26er
Chain never unshipped yet.
Official cafe stop tester
Jmdesignz2
by Jmdesignz2
jekyll man wrote:Not compulsory.
Cool- thanks for info - what trails do you ride and link to pics of set up?
jekyll man
by jekyll man
If you google either peak district uk, or Lake district and mtb'ing you'll find plenty of pics of the sort of stuff i tend to ride.
Steep, loose, rocky (babies head size rocks), along with a mix of trail centre routes.
I'll post a pic later of my set up, but other than it tidying stuff up around the bb area, there's not a lot to see.
I didnt think it would really be an advantage over a triple (being overgeared was the biggest worry) but happily proved wrong :)
edited for (crappy iphone) pics:
ImageUntitled by jekyll man, on Flickr
It's a Hope 32T Retainer narrow/wide chainring, not a 34 as thought
andrewfelix
by andrewfelix
Used to run x9 no clutch with race face narrow wide. 12months of riding very technical terrain and never dropped the chain. Did get quite a bit of slap tho.
TheRookie
by TheRookie
Admittedly running 1x9, but (obviously) not a clutch mech and running a cheap narrow-wide I've never dropped the chain, including fairly aggresive red level trail centre riding, no guide fitted.
Devon
by Devon
I'd say it is preferable, but a decent chainguide (like a blackspire stinger) will do the trick too.
afalts
by afalts
Man I don't get how you guys survive without a clutch if you don't have a chain guide. I have XTR9000 with a wolftooth ring and after a month or so once the clutch starts loosening up I drop my chain as soon as the trail points downhill - even with a new ring and chain. I actually decided to run a light chainguide with the clutch cause I was still getting drops once it got going really fast and rough. Though I'm riding in whistler/squamish BC canada, and I know the trails here are definitely more demanding than most places.
Jmdesignz2
by Jmdesignz2
Interesting - now I am wondering if some Narrow Wide rings retain better than others.
Seems Wolftooth drops more often than Hope, RaceFace and Absolute Black?
Bad news for me since I have the WT ring...
Jaker
by Jaker
I went from std rings 2x10 (Control Tech 40t Alum/26t Experimental Prototype Ti) to 1x10 Wolf Tooth NW 32t Oval and I went from 2-3 drops per ride to no drops in the last 10 rides. I do not have a clutch derailleur nor a chain guide. The 40t was nearly new. However I am running an 11 speed KMC X11SL chain with my 1x10 setup and I think that helps. I now have 3-4 years on this model of chain and I have never broken it. YMMV!
Jmdesignz2
by Jmdesignz2
Jaker- is that on a hard tail or FS ?
Jaker
by Jaker
Yeti ASR5 Carbon, 18lbs 15ozs:
2x10:
1x10:
Jmdesignz2
by Jmdesignz2
How do you like the Magura Marta MT8? I am debating M9000 vs MT8 right now
I heard the MT8 can feel "wooden" ? And levers are a bit spongy?
