Lightning Carbon Cranks Same Spider as Next SL or Sram X1?
Lightning Carbon Cranks Same Spider as Next SL?
Anyone know if the Lightning Carbon Cranks can use the same spiderless chainrings as the Next SL or SRAM X1 series?
I am suspecting yes but want to know if anyone has tried it before I take mine apart...
ok - did some research and exactly same spider interface as Specialized BB30 cranks
No. Not even close.
SRAM pattern:
http://www.absoluteblack.cc/sram-oval.html
RaceFace:
http://www.wolftoothcomponents.com/coll ... face-cinch
Lightning/S-Works:
http://www.wolftoothcomponents.com/coll ... chainrings
SRAM pattern:
RaceFace:
Lightning/S-Works:
However, the chain line for the small ring seems better than what I would get with a spiderless chainring?
I am using 73mm bb and the Lightning cranks big ring in 2x config is way out there -much further than the XT 2x cranks that were on there.
I had to crank out the FD mech almost to it's limits to shift to the Lightning big ring properly
If anyone can chime in on the chain line using a direct mount chain ring on the Lightning cranks on a 73mm bb I would surely appreciate the info
Wouldn't that depend on the company making the ring? And also, the shape of the ring?
For example, Garbaruk has variable offsets/chainlines, depending on ring size AND shape.
http://garbaruk.com/single-oval/oval-sp ... lized.html
http://garbaruk.com/single-rings/direct ... lized.html
