Tuned MTB Stem 98g
what was the initial weight, what did you change?
initially 118 - replaced with much lighter Ti bolts
bought this stem years ago so No exact model
AFAIK - Control Tech road 100mm 31.8mm 6 deg
Edit, it's scandium model
Could probably lose another 15 g by smoothing out some edges but I don't feel like polishing it
I would do it .Also see if you can get the bolts hollowed . Easy to do with a drill press and carbide drill bit . Drill through the centre of the face plate or even better cut the face plate into two sections and remove the centre . Debur the edges and you would save more weight that way without compromising any strength .
