I wonder if its possible to use Narrow Wide Oval Single Chainring on a single speed bike ?
black-by-absoluteblack-narrow-wide-oval-single-chainring:
http://www.chainreactioncycles.com/il/e ... prod131089
Pics of the bike:
Single speed with Narrow Wide Oval Single Chainring
It can and has been done.
http://velonews.competitor.com/2010/08/ ... eed_251593
https://www.youtube.com/watch?v=d8PKBDL6hfg
Small bikes for kinds and city bikes with 3/7 gear hubs have oval chainrings too.
So does my retro, Shimano Exage Biopace, but back on topic.
Yes you can, as stated make sure you set chain tension at point of max tension (larger chainring diameter vertical) it onloy has a small effect but it can be significant!
Just to back up, I use a 34 Qring narrow wide on my SS. It works perfectly.
Weight 74.4kg, FTP 303W => 4.04 W/kg
Retired Bikes
Custom 650B Kingdom Double9
Kinesis Aithein / Kinesis Racelight 4S
Current bikes
Reilly Spectre / Cervelo R3
Pivot Les / Pivot Mach4SL
Ventana El Conquistador
Retired Bikes
Current bikes
