It is currently Tue Feb 28, 2017 4:06 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Fri Feb 20, 2004 3:06 pm
I currently run a Thompson setback post (free with frame) on my Spec M5 HT '04.
I'm 175lbs and ride XC.
I'm keen to get the weight down. Which posts would you recommend for less than £100.
My bike is a HT and I run RC-31 rigid carbon forks. I'm thinking that carbon post is the way forward to get as much vibration damping as possible as its a HT.
Given my stange size of the Spec frame I'll need shims for USE carbon. They weigh in at 22g (I think). Is there a better option?
 Post subject:
PostPosted: Fri Feb 20, 2004 3:13 pm
Administrator
I woudn't opt for shims. The experience that i have with a shimmed post is that the post wasn't gripped good by the shim. I ended up serveral mm. lower after a few k's. You can really feel that.
Why don't you use the tune seatpost. It's light and should be availible in youre diametre.
Good luck!
Quote:
 Post subject:
 Post subject: what size
PostPosted: Fri Feb 20, 2004 4:05 pm
What size post do you need?
.....but it still has to work!
 Post subject:
PostPosted: Fri Feb 20, 2004 4:07 pm
Administrator
Spec mostly uses the hard to get 30.9 posts. :?
 Post subject:
PostPosted: Fri Feb 20, 2004 4:30 pm
I had a USE alien carbon with a shim on my Manitou and it did the job without any problems.
 Post subject:
PostPosted: Fri Feb 20, 2004 4:42 pm
shim is ok but do not grease between the seat-post and the shim. its alright to grease between top tube and the shim. :D
Crashman like crashing, feel the rythem and ride.
 Post subject:
PostPosted: Fri Feb 20, 2004 5:40 pm
Easton EC70 in 30.9. Has a good setback if you are used to the thompson. I use them on all my bikes except for my 29er which has a real long seatpost due to frame geometry. never had one break and easy to adjust. Be sure to mark the angle you have your seat set at for when you want to change saddles.
 Post subject:
There are no new unread posts for this topic. Attachment(s) anyone know the torque spec for this?
addictR1
14
934
Sat May 28, 2016 6:39 pm
BRM View the latest post
There are no new unread posts for this topic. Helmet advise
Champ5000
16
1135
Fri Apr 15, 2016 6:39 am
em3 View the latest post
There are no new unread posts for this topic. Seeking advise on wheelset
in Everything wheels
evan326
19
1129
Wed Nov 23, 2016 1:09 am
nemeseri View the latest post
There are no new unread posts for this topic. Vision Metron 40s: spoke tension even overall but way above spec?
ManekiNico
Mon Feb 20, 2017 7:28 pm
ManekiNico View the latest post
There are no new unread posts for this topic. Brake & der. cable setup - need advise
G6612
Thu Apr 07, 2016 12:54 am
Sweetbabyj45 View the latest post
Users browsing this forum: No registered users and 9 guests
