giant cog question
cyclemanpat
by cyclemanpat
will the Wolf giant cog(40) or E thirteen giant cog work with a sram xx cassette(11-36)? The websites don't say the XX works?
to go faster....just pedal harder!
LeDuke
by LeDuke
The XX cassette is one piece; other than the 11t. You can't remove any of the larger cogs.
cyclemanpat
by cyclemanpat
well darn...thanks!
cyclemanpat
by cyclemanpat
is there any other options for a 40t or 42T on a sramm xx cassette? I was told about ARI cogs....any US companies?
TheRookie
by TheRookie
As you can't remove a sprocket, no company will be able to make one - obviously!
Jaker
by Jaker
Unless you are willing to machine off the 3 largest cogs to the exact correct spacing and then use a 3 cog setup like the Leonardi or Barkaruk 28-40 or 29-42. But then I'm not 100% sure that the freehub drive splines will still be correctly placed with that much machining.
However, if you were willing to give up your 11t, you might be able to do it that way with one of the single giant cogs.
jooo
by jooo
Sure, someone could make a 40 or 42 for an XX cassette but if it mounts straight to the 32, it would be a bit like MegaRange :lol:
LeDuke
by LeDuke
Jaker wrote:Unless you are willing to machine off the 3 largest cogs to the exact correct spacing and then use a 3 cog setup like the Leonardi or Barkaruk 28-40 or 29-42. But then I'm not 100% sure that the freehub drive splines will still be correctly placed with that much machining.
And by giving up your 11t, and adding a 40t or 42t, you basically get the same gearing range as before.
Just heavier.
Jaker
by Jaker
Just heavier.
Very true. Hadn't thought about it that way.
TheRookie
by TheRookie
The only way I could see you could do it with sensible ratio changes would be to machine off the smallest 3 gears and insert a 15 and 13t (with spacer) from a low end SRAM Cassette (bolt together type) or Shimano (riveted). Would add less weight as well
So 11,12,14,16,18,21,24,28,32,36 becomes 11,13,15,18,21,24,28,32,36,42
You could remove the alloy 36 but the smallest narrow wide I have seen is a 40 which is then an 8t jump up from the 32 and a bit much, also then only really useable as a bail out gear so somewhat defeats the object.
Or just buy an XT like everyone else!
ma2xs
by ma2xs
The rear cog on the xx is replaceable and you can remove it. Check this out:
http://www.bikerumor.com/2014/01/09/upg ... -39t-cogs/
http://www.jhcycling.org/blog/2015/4/10 ... cog-review
Jaker
by Jaker
I bought an XT, and swapped out the 28-32-36 for a Bargaruk 29-35-42. So far I love it. And it dropped the weight of my cassette to 260-ish grams.
