stem: tune or extralite?
Dewillem
by Dewillem
Hello
I'll have to buy a new stem soon. The choice is:
Tune Geiles Teil: 120 mm, 119 € and 164 g.
Extralite The Stem: 120 mm, 119 € and 128 g.
Difference is that the first one is cnc-machined and the second one is welded.
Now, the question is, which one would be the strongest and why? Are the UL stems from extralite (98 g) still strong enough? Because I read somewhere that it happened that they broke! What could be pretty ennoying!
I mainly drive on the road to work, but in the weekend I change tyres and dive into the Ardennes in Belgium. So it has to be strong enough for both.
Thanks in advance.
dewillem
nikh
by nikh
Hello,
Have you considered the Syntace F99 stem?
As you pointed out the Extralite maybe prone to breaking, I think they have a new face plate design which should eliminate the problem?
The Tune is nice but expensive.
The F99 is cheaper, stiffer and looks lovely IMO.
Good luck,
Nik.
polaris
by polaris
At 164g the Tune is not very light either.
.....but it still has to work!
elendil
by elendil
The Tune is a very strong stem, but the F99 is strong, too, lighter and cheaper. I got it on my "Enduro" Nicolai Helius CC, no problems (70kg rider weight).
Dewillem
by Dewillem
indeed, it is cheaper and looks pretty good too!
Thanks for the reactions so far.
Nikh? In the topic "FRM direct pull 4", you refered to the Vuelta mag v-brakes, which you bought directly from Nino. Could I ask how much you paid them? And if they are good?
thanks
nikh
by nikh
Dewillem wrote:indeed, it is cheaper and looks pretty good too!
And its pretty light when its tuned with ti bolts!
I haven't installed them yet but he swears by the performance as good if not better than the Avid Mags he was using previously.
You can reach him at: luckynino AT ggweb DOT ch
Pls let him know I sent you :)
extralite
by extralite
Dewillem wrote:.
When I bought two sets from him last week, he was selling them for 95 euros (front and rear brakes plus the levers). The weight can be brought down to 110g with all aluminium bolts and drilled pad carriers. They are slightly fiddly to set up due to them not having linear springs. the plastic shrouding around the springs can break if you overtighten the bolts like I did (3Nm is enough). The power of the brakes is good when set up correctly (similar to XTR v brakes).
Cookie
by Cookie
I have my Extralite UL stem installed on my HT, and it worked like a charm.
(was playing with the idea to go for other brand when it struck me to get extralite UL stem instead)
Just two weeks ago, I used it to for round-island ride and it survived.
Use it wisely and purposefully, and it will survive to serve you better and longer.
Cookie
Stylomilo
by Stylomilo
Cookie wrote:I have my Extralite UL stem installed on my HT, and it worked like a charm.
Cookie
hi Cookie, Crashman here. i got one question for you. How do you use it wisely and purposefully? you used it to for round-island ride ?and how does it survived?curious.... care to share with us please. :D
Crashman like crashing, feel the rythem and ride.
Cookie
by Cookie
How do use it wisely and purposefully?
Is that a question for me??
YES, I used it on round-island ride recently and it survived.
YES, i used it for it intended purpose and it survived also.
Question answered!
:roll: :roll:
Stylomilo
by Stylomilo
Oh dear Cookie, you mean you ride on road only that make you and your stem survived? :D sorry, i really dont get you. :?:
Dewillem
by Dewillem
Ok thank you all for the information
Just one more question. How do I measure the length of the stem? From one end to the other end or from the center of the steerer to the center of the handlebar? Because I don't want to change the configuration of my bike to much.
Thank you
Frankie - B
Administrator
by Frankie - B
All bike measurements are center / center
Good luck!
Joel
by Joel
Frankie - B wrote:All bike measurements are center / center
No true: some frames c-t, road handlebars mostly o-o
Frankie - B
Administrator
by Frankie - B
:?: explain please c-t / o-o
