10spd XTR with SS cage / Saint with GS cage
Ok so I'm going 1x10 on my race HT. I currently have a m985 (shadow+) rear mech, with a medium cage, although it's an XT cage because I broke the carbon XTR one in a crash.
Anyway, I was thinking on buying a saint rear mech and swap the two cages (SS on XTR, GS on Saint), and then put the saint rear mech on my trail bike (that will be in 2x10).
I've checked the different tech docs on Shimano website, and it will be compatible, no worries about that.
Has anyone used a saint mech with a medium cage before?
Is a short cage ok for a 1x10 setup? (using a classic 11-36 cassette)
I know it's not really weight weenie (Saint derailleur is about 270g, vs 190g for XTR shadow+), but it weighs the same as a Zee/SLX rear mech, and is far more durable and quiet so I might as well take a saint for the trail bike...
http://www.pinkbike.com/news/Shimano-Zee-Rear-Mech-tested-2013.html
Why do you want to use Saint? AFAIK the only real differences on Zee are the steel B-knuckle and no 'range change' which is basically for DH bikes. Zee RD's weigh almost exactly the same as Saint.
If all you want to do is use the cage, surely Zee is a better (cheaper) idea?
And if you're doing it for weight savings, a carbon cage would be lighter and not really more expensive.
Pinkbike wrote:We can't help thinking Shimano have shot themselves in the foot with the Zee rear derailleur. After using the Zee mech for a while we are hard-pressed to offer a reason why you would buy the more expensive Saint.
Carbon cages are hard to come by, even the stock xtr ones are more expensive than the complete mech (experience from looking for one when I broke mine). I thought about the zee mech, but it's basically SLX with a short cage, and SLX is way cheaper than zee, while I can get a saint mech from a friend slightly used for about the same price as a new zee. Saint is supposedly much stronger, and has a stronger clutch than zee/SLX, for the same weight.
I'm also switching my trail bike from 3x10 to 2x10, so I'd prefer ditching the non-shadow SGS XTR mech on it to a GS cage mech with clutch. I could buy an XT, but that means buying a short cage for my race bike anyway, which will end up more expensive than the used Saint option.
The only glitch in this plan is that I never heard of anyone putting a medium cage on a Saint, but I don't see where it could be a problem.
Alright I did the switch.
So in the end, my race bike is on 1x10, with a XTR shadow+ rear derailleur using the SS cage from the Saint (11-36 cassette, 36T up front), and the saint got the GS cage from the XTR derailleur, and is used in a 2x10 configuration.
Sorry for the quality of the pictures, cellphone pics!
XTR with saint cage
Full bike
Saint with GS cage
Full bike
XTR with saint cage
Full bike
Saint with GS cage
Full bike
Nice looking Sewanee, I am still using an old Niota Al frame for my 10.1Kg FS 'do most of it all' bike.
Yeah you just need to keep the same type of derailleur, ie clutch vs non-clutch. A Zee SS cage will also fit, and is probably the same as the saint, except for the jockey wheels. For older derailleur without shadow+, you need to find a non clutch cage (m810 Saint for 9spd mechs). I'm not sure a road cage would fit a non clutch mtb derailleur, will have to take a look at the tech docs on Shimano
Fwinns wrote:Yeah you just need to keep the same type of derailleur, ie clutch vs non-clutch. A Zee SS cage will also fit, and is probably the same as the saint, except for the jockey wheels. For older derailleur without shadow+, you need to find a non clutch cage (m810 Saint for 9spd mechs). I'm not sure a road cage would fit a non clutch mtb derailleur, will have to take a look at the tech docs on Shimano
Thanks for the info. I've always wanted a Saint RD- they look absolutely bomb-proof.
