Trail hardtail - Santa Cruz Highball Carbon
mcnik
by mcnik
Hi all,
My first post here I think. Been reading this forum a lot figuring out what parts to get for my new build.
This is a Santa Cruz Highball Carbon frame, '14.
Overall weight is just under 9 kilos / 19.8 Lbs.
I may be able to shave some more weight off, but want to keep it a strong build (so, for example, I am resisting putting Furious Freds on it!)
You can read more at my blog http://niksbikingblog.blogspot.co.uk/20 ... build.html
Any comments or ideas for further weight reduction are most welcome!
Component : Part name : Weight
Frame Santa Cruz Highball Carbon Large 1130
Forks DT Swiss XMM 120 Carbon Tapered, 15mm 1610
ForkSteerer Plug DT Swiss Carbon Steerer Plug 47.7
Fork Rem L/out Leaver DT Swiss lockout 12.1
Fork Rem L/out Cable (uncut) Lockout cable 34.2
Fork Rem L/out Adjuster Lockout adjuster 3.7
Wheels Light Bicycle Hookless Rim/DT Swiss Straight 240 hubs 1562
Front Skewer / axle DT Swiss 15mm axle 71.9
Rear Skewer / axle DT Swiss RWS 12mm thru axle 63
Tyres 2 x Continental XKing RaceSport 29x2.4 609.8
Tyre 2 2 x Continental XKing RaceSport 29x2.4 613.3
Tubeless kit / Tubes strip, valves, minimal sealant 160
Headset Bottom Cane Creek 110.EC49/40.Bottom Assembly 70.3
Headset Top Cane Creek 110.ZS44.Short.Top Assembly 44.5
Stem "Richey WRS C260 80mm 98
Handlebars Mt Zoom Ultralight Flat Bar 126.5
Grips LizardSkins DSP grips 22
Bar Plugs Specialized Alu Bar Plugs 23.7
Barends Xon Bar Ends 53.4
Seatpost Thomson Masterpiece 30.9mm 350mm black 192
Seatpost Clamp Santa Cruz clamp 20.8
Seat S-Works Phenom Carbon 150.3
Bottom Bracket BOR External BB30 91.4
Cranks + chainring Raceface Next SL 424
Pedals Crankbrothers Eggbeater ti 183
Rear mech Shimano XTR M986 Shadow+ 10 Speed Rear Mech 214
Shifter + Inner Shimano XTR M980 (119.4 - 18.6 orig clamp) inc inner 100.8
Outer Outer (uncut) 58.8
Cassette XT 10 speed 11-36 330
Chain KMC X10-SL 240
Brake mount adapter front
Brake mount adapter rear Shimano Rear IS 160mm to 160 post 15.3
Brake mount adapter bolts rear Shimano steel bolts x 2 9.1
Front Brake inc Leavers + Calliper Hope Stealth Race Evo X2 200.5
Matchmaker Shifter Mount Matchmaker Shifter Mount dif (11.9 total) 5.5
Rear Brake inc Leaver + Calliper Hope Stealth Race Evo X2 rear 212.8
Rear Disc Hope Floating Race Rotor 160mm 81.5
Front Disc Hope Floating Race Rotor 160mm 81.3
Front Disc Bolts Hope Titanium Bolts 7.3
Front Caliper Bolts + Washers Hope Titanium Bolts 8.1
Total = 8.98 kg
Total = 19.80 lbs
maddog 2
by maddog 2
Nice. My Cube 29er is the same weight but I'm rigid (Kinesis IX fork) so you've done well to get under 9 with a bouncy fork.
You save on the cranks (I'm XT), pedals (XT), hubs (Hope) on initial inspection.
vortrex
by vortrex
Sweet ride. I was a little over 19lbs with my Scott Scale/SID build. Looks like most of that was made up in the frame weight difference.
roadieboy
by roadieboy
Really nice build, I am really liking the new Highball frames.
gfeldy
by gfeldy
mcnik wrote:Handlebars Mt Zoom Ultralight Flat Bar 126.5
What are your thoughts on this bar?
~GFeldy~
S Works Tarmac w/ EPS
S Works Epic HT Blurple tuned
Kitsbow
S Works Epic Blurple tuned - Sold :doh:
FS-i - Sold
Scalpel custom - Sold
EVO - Sold
