Steel or Titanium Disc Brake Caliper Fixing Bolts?
Valbrona
by Valbrona
I am a Roadie setting up my first disc brakes - mechanical on a road bike.
Do you MTB people only use M6 steel bolts to fix calipers on or are titanium bolts thought to be strong/safe enough in this application?
Thanks.
TheRookie
by TheRookie
Ti bolts are fine, although they are pricey and for the same money you can save more weight elsewhere.
mattr
by mattr
A ti bolt set for my mtb brakes is about £35-40 an end, Inc lever clamps, disc bolts and other bits and pieces, about ~12 bolts per brake.
Weight saving (from their figures), was about a colossal 15 grams.
On the plus side, they don't corrode and they look shiny.
Down side is they may gall (haven't yet, used copperslip).
Certainly wouldn't have bought them, but they came as a freebie with the brakes
bikewithnoname
by bikewithnoname
Ti. Don't forget a little loctite though.
Valbrona
by Valbrona
DanW
by DanW
Why is that Juan?
I was always under the impression that very high torque bolts (10Nm+?) should be greased/ copper slipped but lower torque bolts should use threadlock (less than 6Nm maybe?).
To be honest I used copper slip on Ti bolts religiously in the past and now religiously threadlock them for some reason but haven't had a problem either way so I guess the answer is it doesn't really matter :D
mattr
by mattr
TBH, a well (regularly) maintained bike with fasteners torqued correctly *shouldn't* need loctite in the vast majority of locations that it's used. Better off using grease/light oil/copperslip to get the torque (and end load) correct than relying on loctite to hold it in. Maybe 15% (?) of those bolts that have loctite actually need it.
Its more than likely only there to allow for the fit and forget crew who won't look at a part until its broken, its similar to the old wire locked shimano caliper bolts. That no one ever fitted the wire to!
DanW
by DanW
That sounds like good logic mattr and makes sense.
bikewithnoname
by bikewithnoname
Well I've been using ti bolts and loctite on my caliper bolts and rotor bolts since the 90's and never had any issues with bolts coming loose (or any issues removing them either).
Use grease if you like, I'm sure getting them torqued down correctly is the most important thing
stuka666
by stuka666
Another one using ti with no problems.
Valbrona
by Valbrona
Interestingly, I have never seen OEM or 'proper' aftermarket Ti fixing bolts for disc brakes (I am new to discs), but I have seen aftermarket Ti rotor bolts from Giant.
kode54
by kode54
Ti. had steel ones corrode after riding in wet and muddy conditions. like others have said...use anti-seize.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
mattr
by mattr
Valbrona wrote:Interestingly, I have never seen OEM or 'proper' aftermarket Ti fixing bolts for disc brakes (I am new to discs), but I have seen aftermarket Ti rotor bolts from Giant.
hope provide full sets for their brakes, fairly OEM.
scant
by scant
my Shimano M987 Race brakes also came stock with titanium caliper bolts.
UpFromOne
by UpFromOne
another vote for ti with anti-seize
